Whats Your Current LNF Setup
Old Nov 17, 2012 | 05:52 AM
  #51
paintballerr78's Avatar
2010 ss/tc
Pwerks 5557 dbb turbo kit
Catless DP
Straight pipe side exhaust
E47 hp tune
Pretty much it for performance...
Future mods after deployment
5858 dbb
ZZP stage 2 built 5speed since my tranny blew up.
ZZP built head
Coils
Rims
Tires
Old Nov 17, 2012 | 11:24 AM
  #52
kdub1492's Avatar
Well here we go....
Engine:
Cylinder Head -
WERKSracing high rpm single valve springs
WERKSracing MLS head gasket
WERKSracing high strength timing chain tensioner
ARP head stud kit
Short Block -
WERKSracing balanced rotating assembly
Wiseco Forged LNF turbo pistons
Carillo Forged A-Beam connecting rods
ZZP Intercooler & Chargepiping
K&N SRI
ZZP 3" Catless
HAHN exhaust w/muffler delete
Performance Autowerks Prototype WR-3
Apperance/Exterior
Custome Retro's
MSR 045's
SSC's
Powell Bar
Powell Mounts
Tinted
Tinted Tails
Think that's it....
Old Nov 17, 2012 | 12:50 PM
  #53
Team SS's Avatar
TTR Powered
Originally Posted by paintballerr78
2010 ss/tc
Catless DP
E47 hp tune
5858 dbb
ZZP built head
Coils
Rims
Tires
Coils as in Coil overs lol
Old Nov 17, 2012 | 02:39 PM
  #54
SSlobalt's Avatar
Originally Posted by prevsrt4owner
I'm feeling lonely as hell right now. I think I might be the only stock one on the planet.
I stayed that way for the first year.
Old Nov 17, 2012 | 04:25 PM
  #55
serega12's Avatar
Originally Posted by Team SS
A Downpipe gains are about the same as an CAI for the LNFs. about 10whp gain over the stock
Really? That's quite disappointing. I thought opening up the exhaust on a turbo set up would gain more. Is it because it's already maxed out or because it's direct injected?
Old Nov 17, 2012 | 08:53 PM
  #56
SSSnoop's Avatar
You have to think about what that stock turbo is - it is the primary restriction as much as it is the power-improver; opening up behind the turbo is not going to have the same effect as in an N/A car. The stock on a 2.0 LNF is "acceptable" in terms of flow post-turbo, so the gains are not as impressive. If you go hairy-*****-to-the-wall on a turbo upgrade, maybe these numbers would be different!
Old Nov 17, 2012 | 08:59 PM
  #57
SSSnoop's Avatar
Veteran plates = No DEQ (emissions test) in Oregon. So catless DP wouldn't get me in trouble with the law. Gains (with a proper tune) on a TC car should be quite noticeable. Am I correct?
Well, theoretically emissions laws are federal....
Doubt you'll get in trouble with the po po, and considering no inspectors I know if know the difference between a catted and catless dp......
I was just saying my personal push is to make the performance mods on all my cars "legal" (note the quotes)!
Old Nov 17, 2012 | 09:01 PM
  #58
Team SS's Avatar
TTR Powered
"legal" as in " what they don't know, won't hurt them"?
Old Nov 17, 2012 | 09:10 PM
  #59
SSlobalt's Avatar
1. ZZP intercooler.
2. ZZP catted downpipe.
3. HPT Suite with IamBroke (Tom) E47 21 psi tune.
That's it. Fun for years, reliable, and safe.
Old Nov 17, 2012 | 10:34 PM
  #60
Team SS's Avatar
TTR Powered
Originally Posted by SSlobalt
1. ZZP intercooler.
Simple, but yet fun lol. Good Combo man
Old Nov 17, 2012 | 11:04 PM
  #61
Nfamous60's Avatar
Originally Posted by kdub1492
Well here we go....
Engine:
Cylinder Head -
ARP head stud kit
Short Block -
K&N SRI
ZZP 3" Catless
Apperance/Exterior
Custome Retro's
MSR 045's
SSC's
Powell Bar
Powell Mounts
Tinted
Tinted Tails
Think that's it....
damn looks and sounds good, for the springs did u keep the stock retainers or did u upgrade, also with that head gasket wut is the moost boost you can put on it, i see on their site their race gasket is only good to 30psi
Old Nov 17, 2012 | 11:06 PM
  #62
kdub1492's Avatar
Stock retainers, and I believe Matt had the head gasket on his big turbo build and he ha at least 33 on it for a while and it was fine
Old Nov 17, 2012 | 11:36 PM
  #63
SSlobalt's Avatar
Thanks, man. That was the plan. These cars will handle 320hp/350tq with no issues at all. Pouring money into them is ridiculous, IMO. Know the limits of the car and stick to them. Easy peezy. Have fun!
Old Nov 17, 2012 | 11:53 PM
  #64
Team SS's Avatar
TTR Powered
haha i pushed mine passed the limit once lol. thats why i'm fully built now
Old Nov 18, 2012 | 12:14 AM
  #65
Mitchell's Avatar
2010 SS/TC
BNR GT2871
Treadstone TR10 intercooler
Treadstone charge piping
Treadstone CAI
Turbosmart Raceport BOV
TurboXS Catless DP
RPT E47 Tune
Think thats it haha
Old Nov 18, 2012 | 12:19 AM
  #66
Wert842's Avatar
All these bigger turbos make me jealous and realize I have no money...
Old Nov 18, 2012 | 03:41 AM
  #67
Stamina's Avatar
Engine Build/Mods:
ZZP Girdled Block
Wiseco Forged Pistons
ZZP 4340 Rods
ZZP Neutral Balance Shafts
ATI Balancer
ZZP Stage 1 Ported and Polished Head
ARP Head Studs
ZZP Stage 1 Cams with Enlarged Fuel Lobe
ZZP 82lb Valve Springs
Fidanza Lightweight Flywheel
ARP Flywheel Bolts
ZZP Stage 4 Clutch
Other Power Mods:
K&N SRI
CIA CPs H+C
ZZP IC
Werks Phenonlic Spacer
CIA Catted DP
MPx Catback
Trifecta Dual-Tune (Usually running E85, unless I'm doing a roadtrip or something with it.)
Suspension/Brakes:
Pedders Coilovers w/Camber Plates
Steering Rack Spacers
Powell Raceshop Spherical Control Arm Bushings
Powell Raceshop "Street" Rear Sway Bar
Slotted R1 Rotors w/Ferodo front and Hawk HPS back
Other Misc Stuff:
MPX Shorty Antenna
Saab Shifter Bushings
CF Wing Insert to stiffen things up
Vortex Generators
Weight Reduction
Evap Mod
Vacuum Tank Bypass/Delete
Dashdaq
Possible Future Stuff:
Install the ZZP brake lines I've had laying around for a while.
Figure out some sort of stronger tranny solution to ensure I stop going through transmissions... and then go ZFR.
Stop modding and enjoy a quick and well balanced car for years to come. :P
Last edited by Stamina; Nov 18, 2012 at 04:26 AM. Reason: Forgot a couple recent mods/tweaks
Old Nov 18, 2012 | 03:44 AM
  #68
AyrtonSenna's Avatar
Originally Posted by Stamina
Engine Build/Mods:
ZZP Girdled Block
ZZP 4340 Rods
ATI Balancer
ARP Head Studs
ARP Flywheel Bolts
ZZP Stage 4 Clutch
Other Power Mods:
K&N SRI
CIA CPs H+C
ZZP IC
CIA Catted DP
MPx Catback
Trifecta Dual-Tune (Usually running E85)
Suspension/Brakes:
Other Misc Stuff:
MPX Shorty Antenna
Vortex Generators
Weight Reduction
Evap Mod
Dashdaq
Power?
Old Nov 18, 2012 | 03:51 AM
  #69
Stamina's Avatar
Originally Posted by AyrtonSenna
Power?
No idea. I've never dynoed it in any of its configurations over the years.
Old Nov 18, 2012 | 03:54 AM
  #70
what turbo are you running?
Old Nov 18, 2012 | 04:00 AM
  #71
Stamina's Avatar
I've kept the K04, because up until recently it had one of the best curves for road courses, which was what I wanted the car to be more geared towards versus outright power (part of the reason peak power numbers weren't really of interest to me).
Now that the ZFR is around, it seems that I could possibly have my cake and eat it too, and I'm hoping that I'm finishing doing the support mods to safely bolt one on long term. It'd allow me to keep the road course quick-and-nimble nature of it while being able to do respectable on highway rolls too... with a switch-flick or reflash of a tune.
Old Nov 18, 2012 | 04:02 AM
  #72
serega12's Avatar
I've kept the K04, because up until recently it had one of the best curves for road courses, which was what I wanted the car to be more geared towards versus outright power (part of the reason peak power numbers weren't of interest to me).
Now that the ZFR is around, it seems that I could possible have my cake and eat it too, and I'm hoping that I'm finishing doing the support mods to safely bolt one on long term.
Love your sig. Respect.
Old Nov 18, 2012 | 04:09 AM
  #73
Stamina's Avatar
Thanks!
Old Nov 18, 2012 | 07:08 AM
  #74
Nfamous60's Avatar
Stamina you got a bad car man, one of my top choices for a well built balt. Also wuts the weight reduction and evap mod? lol also wut the hell are vortex generators?
Old Nov 18, 2012 | 12:31 PM
  #75
serega12's Avatar
Evo X has them from the factory... not sure about others. Originally found on aircraft wings.
EDIT: Here's Wikipedia article to the original vortex generator: Vortex Generator - Wikipedia
