Whats Your Current LNF Setup
Old Jan 17, 2013 | 06:05 PM
  #201
Dart_SI's Avatar
yea, the transmission. lol. already broke one of those. not much i can do about that except get a upgraded one (i have a 4.05 now) and hope that one doesnt break. even a couple 4.45's have broke. sucks.
Old Jan 17, 2013 | 06:16 PM
  #202
LE5_AJ's Avatar
I haven't been around here for a long time. Who's the one selling the transmissions? What's special about them? Just the different final drive?
Old Jan 17, 2013 | 06:20 PM
  #203
cmiller8006's Avatar
Originally Posted by LE5_AJ
Yea it's almost the most important mod.
And if you're breaking **** from traction it's just showing you the weak links.
Not a mod at all, if one can drive they can drive, not a mod. I can drive and row gears pretty damn good, but never say I have a driver mod. Kinda dumb. And I have plenty traction at 500+ whp.
Old Jan 17, 2013 | 06:29 PM
  #204
LE5_AJ's Avatar
Cool its not a mod just a word, but if one person drives better then the other it sure helps make their car look quicker. It's nice to see you have plenty of traction. What do you have done other then running slicks at the track?
Old Jan 18, 2013 | 12:23 AM
  #205
Nfamous60's Avatar
FasterIsBetter how you like that aeromotive pump, i read alot of issues mounting it, and fitment on the LNF's
Old Jan 18, 2013 | 02:42 AM
  #206
Fastgti69's Avatar
Originally Posted by FasterIsBetter
ZZP Girdled 2.1L Block
ZZP 4340 H-Beam Rods
Wiseco 88mm Forged Pistons
Ported Stock Intake Manifold
3.6 DI Throttle Body
ZZP Neutral Balance Shafts
ZZP Ported Head
ARP Head Studs
ZZP #82 Valve Springs
ZZP S1 Cams
ZZP 5th Injector
Aeromotive Stealth 340
Magnaflow Bullet Side Exit
Bullseye S256ET ZZP Turbo Kit
ZZP Chargepiping, 50mm BOV, and FMIC
ZZP S4 Clutch
Fidanza Aluminum Flywheel
ARP Flywheel Bolts
ZZP Stage 2 4.45 Trans w/LSD
Pedders Coilovers
Moog Endlinks
OTTP Street Sway Bar
Autometer Sport Comp II Boost Gauge
Aeroforce Interceptor
TWM Short Throw w/ all goodies
And thats about all I'll list...
Ummm, that's one healthy mod list. Wow lol
Old Jan 18, 2013 | 03:14 AM
  #207
raver0789's Avatar
Made 449whp and 360wtq at 26/27psi on pump gas.
Stock motor
Stock trans
ZZP Bullseye s256et .55 AR turbo (Full boost before 4k)
ZZP Stage 4+ Clutch
ZZP Throwout bearing
ZZP Full-Size Intercooler
ZZP Upper and Lower Charge Pipes W/ MAF Relocate
ZZP Big Turbo downpipe, with Cat
ZZP BOV
ZZP Wastegate Tube
ZZP Full 3" Exhaust, No resonator
Tial 38mm wastegate
AEM Truboost Manual Boost Controller
ZZP Triple guage pod
Triple Aeroforce Interceptors
ZZP Lightweight Race battery
Powell LNF Anti Oil-Starvation Oil Pan
Powell Harness Bar
Powell XXX Bar
Powell Tow Hook
Powell Control Arm Brushings
Powell YYZ V2 Springs
Lightweight Silver Enkei PF01 18 x 9.5 wide rims (Powell's old rims)
Nitto R compound NT01s all around
5 x 114.3 HUB Conversion
Old Jan 18, 2013 | 08:44 AM
  #208
Cobe's Avatar
Lol in all honesty im pretty good too . Lol If you do it right you can get traction with our cars.
Old Jan 18, 2013 | 11:56 AM
  #209
Nfamous60's Avatar
^^^ yea after you start moving and not mash the pedal.
Old Jan 18, 2013 | 12:06 PM
  #210
EMAC X 61's Avatar
09 SS coupe
stock turbo
synpase chargepipe
tr8 intercooler
k&n sri
zzp catless dp
magnaflow exhaust
rpt tuned
Old Jan 18, 2013 | 03:08 PM
  #211
LE5_AJ's Avatar
Yea roll into the throttle till about 60 then you have traction.
Old Jan 18, 2013 | 06:01 PM
  #212
The right foot lol. No but I have a lot of time spent with the boost control and stuff like that
Old Jan 18, 2013 | 06:37 PM
  #213
LE5_AJ's Avatar
Yea I understand, my buddy has an evo and i'm almost jealous of the amount of traction he has. I've been pondering the idea, after I finish my other stuff, of running the "wot box" so i have the adjustable rev limit and boost control for launching for consistency. Then i wanted to run this setup to prevent weight transfer https://www.cobaltss.net/forums/6551781-post3.html I feel these are better then the footballs since you can adjust both pressure equally and easily. Then for the track i wanted to run limiting straps on the front suspension one of my friends did it in his boosted Integra and it seemed to help. As far as slicks are you guys running 26x11.5x17 et streets?
Old Jan 18, 2013 | 06:53 PM
  #214
No I am on m and h 24.5's on a 15" rim. I found that if you maximize the stiffness in the rear you don't need those straps. I no longer use them. And if you have coils it's even easier. Front soft rear hard and your good to go.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
ThoR294
Oct 4, 2015 08:44 PM
dieGone
Oct 1, 2015 06:27 PM
patooyee
Oct 1, 2015 01:07 PM
