white smoke???
You've never seen a boosted engine blow white smoke due to a lean condition?? Strange, because that's usually a tell tale sign of running lean in my field of work....
Either way, me nor tom.g said that it was definitely a lean condition.. it was just speculation. As is every post in this thread unfortunately. However, I do agree that it is most likely tune related.... again, I'm just speculating though..
And the colors 09CobaltSS1 describes below are the ones I was taught back when I used to work at a shop.
white smoke: possible lean condition, bad head gasket, warped head and/or coolant being burnt
gray/blueish smoke: oil being burnt in some form, or even bad valve guide(s) or seat(s)
black smoke: rich condition and/or ignition problem causing rich condition
I've never seen the SS/TC's puff white smoke from running lean but back in my Talon days white smoke 9 times out of 10 was a safe bet you were running lean.
I gotta ask ya. How does a LEAN condition cause smoke? Burnt air makes zero smoke. A LEAN condition exists when there is too LITTLE fuel being burned. LESS fuel would equal LESS emissions. Smoke included. A RICH condition will make BLACK smoke. Emissions from a rich running engine contain excess CARBON. Carbon is BLACK.
If that is all it is just change your plugs after the smoke show stops. Take it easy on the car for now. The smoking should stop pretty quickly. Might want to run some fuel injector cleaner through the car as well to clean the gunk off the piston and the valves.
running rich maybe?, my neighbor didn't recognized my brother's RX-8 and thought me and my brother were trying to jack his ****, so he hit the gas hard and a trail of whiteish smoke, I told him about it and he said his car was running really rich, cause his tune was not all set yet or something like that, been awhile and can't remember
My 98 eclipse GSX ran rich when I put in my 580s and the 16G. I tuned it out with the SAFCII
I was running it with open downpipe no exhaust. And MY car would shoot flames out the back during shifts. Scared the crap out of everyone. I miss that car just raw power.
That sounds a lot easier than ripping the engine apart and cleaning it. How long should it take to make the smoke go away. My car is currently dead because this happened while changing the alternator so I never ran it for more than 15 minutes because I got scared of the smoke.
