white smoke??
Old Mar 20, 2011 | 02:17 PM
jaygo7007's Avatar
white smoke??
so yesterday after installing the forge motorsport bpv i took ot for a test drive.... awesome device by the way, but while punching it to see if it holds the boost it actually boosted to 24-25 instead of 22-21, also when i redlined it i noticed quite a bit of white smoking from the tail pipe, so i let the car cool down and cut off. started it later it sounded like something from the engine knocking or grinding. im like wth now. you guys have any clue what it might be???
another note while i installed the bpv i took off the intake coupler right under the bpv and notice there was oil on the coupler is this normal? should i be worried
Old Mar 20, 2011 | 02:20 PM
Shibito's Avatar
Oil in the Intake coupler means it's time to put your car back to stock and take it to the dealer.
Old Mar 20, 2011 | 02:22 PM
jaygo7007's Avatar
oh hell, well im tuned so i dought i get it warrantied. damn just my luck!!! oh well it was fun while it lasted
Old Mar 20, 2011 | 02:23 PM
Shibito's Avatar
Get tuned back to stock.
Old Mar 20, 2011 | 02:25 PM
jaygo7007's Avatar
gotcha. thanks. you have any idea what it could be. damn this sucks lol
Old Mar 20, 2011 | 02:27 PM
Shibito's Avatar
I've seen it twice. One was a fried 2nd cylinder and one was a blown head gasket. Both times resulted in new motors.
Old Mar 20, 2011 | 02:29 PM
jaygo7007's Avatar
i take it a head gasket is better than a cylinder huh??? how much would a new moter be??? expensive???
Old Mar 20, 2011 | 02:32 PM
gotboost?17's Avatar
Nothin Stock
i have black grimmy oil in my intake and freast oil sitting in the turbo inlet u think the same thing too ? what about a catch can? no smoke or weird noises tho
Old Mar 20, 2011 | 02:35 PM
jaygo7007's Avatar
i was thinking catch can also
Old Mar 20, 2011 | 02:38 PM
BooSSted's Avatar
This is why you should spend an extra bit of money and buy the tuning cables and software so you can revert back to stock if needed. A trip to the dealer should be your first step. The worst thing they are going to say is that they won't be covering it.
A new engine is going to cost you a couple grand. Might as well build the dead one with proper parts so this won't happen again.
Old Mar 20, 2011 | 02:43 PM
jaygo7007's Avatar
ok ima go back to stock and take all the mods off but wont they find out i was tuned???
also if i go to the dealer and explain my problem, how would i explain that, whenever i redline it white smoking comes out???
just what i needed
and whats the fee for them to look at it anyone now?
Old Mar 20, 2011 | 02:51 PM
Nothin Stock
isnt it normal to have a lil oil in the inlet of the turbo on these cars? but if ur cars blowin smoke and knockin im sure its fucked
Old Mar 20, 2011 | 02:54 PM
jaygo7007's Avatar
it will be my luck if its fucked.... ill see soon
Old Mar 20, 2011 | 02:57 PM
Shibito's Avatar
Both guys I spoke of just flashed back to stock using HP Tuners and the dealers put in a new motor under warranty.
They can't tell you they won't warranty it even if you tell them you're seeing the smoke near redline. The redline's supposed to be there to protect the motor right? Well it's not doing it's job
AndrewSS/TC's Avatar
I have oil in my intake/turbo inlet. Been told it's blow by from the PCV.
Old Mar 20, 2011 | 03:00 PM
jaygo7007's Avatar
is the pcv that lil thing that connects to the intake??? cuz thats a lil oily itself..
well wish me luck guys im just worried about them finding the tune
Old Mar 20, 2011 | 03:02 PM
Shibito's Avatar
Don't take it in tuned or they will and they'll have GM cancel the warranty via your VIN.
Old Mar 20, 2011 | 03:05 PM
jaygo7007's Avatar
no ima getit flashed to stock but i thought they could still detect it
Old Mar 20, 2011 | 03:06 PM
ripped's Avatar
you probably have a craked piston or burnt piston rings., your going to end up having to get a new motor
apparently where finding out on the kappa forums that the pistons cant handle over 300whp for long, its just starting to show all over my forums now.
Old Mar 20, 2011 | 03:07 PM
Shibito's Avatar
Turns out they can't unless they do a LOT of digging, but they won't. Funny because so many people were buying 2nd ECU's when the LNF first came out.
Old Mar 20, 2011 | 03:09 PM
jaygo7007's Avatar
are you seriously!!!!!!!!
Old Mar 20, 2011 | 03:10 PM
jaygo7007's Avatar
i couldnt just replace the piston or rings????
Old Mar 20, 2011 | 03:11 PM
Shibito's Avatar
Ya. I've seen several LNF's go in with just a stock reflash and get warranty work after the dealer checked the tune. They pretty much won't dig to find out it was reflashed unless someone tells them you did because it's too much time for them to pay someone to do it and have a chance that they find nothing.
New motor under warranty is better.
Old Mar 20, 2011 | 03:12 PM
jaygo7007's Avatar
hopefully this works. if so i wouldnt want to get tuned again maybe the stage 1 if that
Old Mar 20, 2011 | 03:13 PM
tom.g's Avatar
If there is just a little bit of oil in your intake that is completely normal it's just blow by. Clean your intake install a catch can and I'm willing to bet you don't see any more oil in your intake. If your blowing smoke and knocking that's a different story.
What would make you say that just because there is a little oil in the intake he has a serious problem Look in the intake of every car (without a catch can) on this site and I bet you they all have a little bit of oil there.
That's exactly what it is.
