white smoke??
Old Mar 23, 2011 | 10:38 AM
  #76
jaygo7007's Avatar
[QUOTE=ssblackstealth;5653074]
Originally Posted by tom.g
God I hope there is nothing wrong with your car because your tune is the kind of tune most guys with TF run. And if you crack a ringland with a tune like that QUOTE]
yea man the tune isnt "all out"
but i think if it was gunna go at least it wasnt too bad....
the dealer here is stupid so im taking my car to another one to get it lookeed at
they are saying i have smoke coming out my exhaust like crazy, knock, bad misfires at idol, and can smell a strong oil burning smell because i have a bad sensor.........
they want to charge another 85 to do a compression check
a shop here 160 for a compression and leak down test.
another wanted 150 to change my spark plugs ( i dont have the tools to do so)
Old Mar 23, 2011 | 10:40 AM
  #77
tom.g's Avatar
Good luck ssblackstealth hope you get everything sorted out man
Old Mar 23, 2011 | 12:23 PM
  #78
ssblackstealth's Avatar
corn gas ftw....
thanks bro!
its sounds like its gunna be a long process, i hope ill be up and running in time for the ced meet in june
Old Mar 23, 2011 | 12:46 PM
  #79
jaygo7007's Avatar
anyone know the best gap size to gap the ngk ltr6ix-11?
mods if needed is in sig
Old Mar 23, 2011 | 01:38 PM
  #80
silverbullet08's Avatar
Originally Posted by joshc.
Who have you tuned in Houston? Your car doesn't happen to be silver and in the Kingwood/Huffman area?
This is all I will add GM and the ecotec have a horrible track record of ringlands cracking I have seen it in every engine of the ecotec line except the 1.8 and new 1.4. Supposed engines that can take certain power mean nothing just because one did it does not mean another will. Its like the crankwalk issue with DSMs there are 500hp 7bolt 4G63s roaming Houston yet at this point there crank is supposed to have walked yet no issue . But others have had this issue.
For example ask Cubaniche about his LNF balt it will throw you for a loop compared to other cars with the same mods.
Quite a few here in Houston. Only two that actually have acounts here on SS.net that i know of. Ryan and clint. Red and yallow balts. Yes i am the silver one over here in huffman kingwood area. I go to kingwood college and live out here in huffman. I know what your saying that some cars just have problems, and there is no way to guarantee a car wont blow up due to a tune. It just helps quite a bit when things are closer to spec than stock when your adding power. Whats up with Cubaniche's car? guess i havnt heard the stories with it? fill me in.
Old Mar 23, 2011 | 01:39 PM
  #81
I run mine about .32-.33 any larger or smaller and i get random misfires at WOT
Old Mar 30, 2011 | 08:21 PM
  #82
corn gas ftw....
well the rings and piston in cylinder 1 were murdered and the wall of cylinder 1 is messed up as well....so the dealer is either going to relpace/fix my motor, which is really expensive since the cylinder wall is messed up or drop in a new motor
all covered under warrenty
Old Mar 31, 2011 | 10:42 AM
  #83
tom.g's Avatar
Did you leave any bolt-ons on when you took it in?
Old Mar 31, 2011 | 10:50 AM
  #84
corn gas ftw....
only stuff that was left on was my mpx ic, zzp cold pipe, and aem wide band
Old Mar 31, 2011 | 12:38 PM
  #85
tom.g's Avatar
Oh and out of curiosity what was your commanded Lambda?
Old Mar 31, 2011 | 01:06 PM
  #86
08TCmavrk1181's Avatar
Mine had a two cracked cylinders. Had to get a new long block. It was still bone stock also...had it for a year and a half at the most..dealer said it was factory problem. A guy on here told me it was because of a the Aluminum molding in the factory sometimes bubbles get in the cylinders and when the motor is used the bubbles in the aluminum pop and crack. Which lets coolant into the cylynders. and burns it
Old Mar 31, 2011 | 02:59 PM
  #87
corn gas ftw....
yea thats exactly what i heard as well.....
mine was only stock to take it to the dealer tho hehehe
@tom.g im not sure on the lambda, id have to ask vince...
car will be ready tomorrow!!!
Old Mar 31, 2011 | 03:10 PM
  #88
ronn's Avatar
Originally Posted by ripped
you probably have a craked piston or burnt piston rings., your going to end up having to get a new motor
apparently where finding out on the kappa forums that the pistons cant handle over 300whp for long, its just starting to show all over my forums now.
Maybe you should post that over on this thread:
https://www.cobaltss.net/forums/2-0l...d-ever-244457/
Old Mar 31, 2011 | 03:14 PM
  #89
ronn's Avatar
so yesterday after installing the forge motorsport bpv i took ot for a test drive.... awesome device by the way, but while punching it to see if it holds the boost it actually boosted to 24-25 instead of 22-21, also when i redlined it i noticed quite a bit of white smoking from the tail pipe,
I keep sayn this OVER AND OVER....ya don't want 24+ boost... BTW, that's not the purpose of the Forge Unit.
Old Mar 31, 2011 | 03:41 PM
  #90
corn gas ftw....
this is true, with my forge installed my 23psi tune saw 25psi....as well might turn it down to 22 or so to offset the gain or change in psi
Old Apr 3, 2011 | 08:45 AM
  #91
jaygo7007's Avatar
i know thats not the purpose of the unit... i just stated the observation i made between stock and the installed unit.
when i get tuned ima get it turned down
Old Apr 3, 2011 | 12:12 PM
  #92
HHRSSouth's Avatar
I ran a Trifecta tune @ 26 psi for over a year on the K04 before I upgraded turbos.
When I pulled the K04 turbo off to exchange it for the BNR upgrade, it still had minimal side to side shaft play (what is expected without oil in the turbo).
Old Apr 3, 2011 | 05:52 PM
  #93
ronn's Avatar
On 26 lbs, It's not the turbo i would be worried about
Old Apr 3, 2011 | 05:59 PM
  #94
corn gas ftw....
yea the turbo holds up great its the rings that go....hahaha
Old Apr 12, 2011 | 01:07 AM
  #95
hope the new engine works out for ya dude
Old Apr 12, 2011 | 09:17 AM
  #96
corn gas ftw....
thanks a lot man!! its workin like a champ so far
Old Apr 12, 2011 | 01:19 PM
  #97
yea exactly what mine did. When I got the new engine I broke it in for about 250 miles and let it loose and its been running fine since.
Old Apr 12, 2011 | 01:22 PM
  #98
corn gas ftw....
good to know!! lol
broke her loose at like 450miles
Old Apr 12, 2011 | 01:47 PM
  #99
RiceCop's Avatar
All this talk about blowing motors is making me want to just go back to stock and get rid of the car.
Old Apr 12, 2011 | 09:17 PM
  #100
importkiller's Avatar
Yeah because Subaru's, Mitsubishi's and Mazda's never blow there motors when pushed!
