white smoke??
If there is just a little bit of oil in your intake that is completely normal it's just blow by. Clean your intake install a catch can and I'm willing to bet you don't see any more oil in your intake. If your blowing smoke and knocking that's a different story.
What would make you say that just because there is a little oil in the intake he has a serious problem
Look in the intake of every car (without a catch can) on this site and I bet you they all have a little bit of oil there.
That's exactly what it is.
like i have a catch can but i donno where u put it could u please help....is it the line goin from the intake to the VC or the turbo to the VC? also how do u get this braided hose off?
White smoke was coming out of my exhaust only when in neutral and it was also misfiring like crazy while driving so I took it in and the dealer told me it was my turbo. I replaced it and had the same problem. All my mods are still on the car and they are now putting in new pistons and rings under warranty. I really don't know what even caused this to happen.
Im pushing over 300hp and have been for over 30,000 miles of intense abuse. I hate to talk **** about a tune, but just throwing the facts out there, this is the third car that has been blown up buy this tuner including his own personal car that i know of. Of coarse any idiot can dog one of these cars to the point of blowing up if you purposly abuse it, but obviously there is something not right on his tunes that needs to be changed.
There are hundreds of 300+WHP LNF's on this site who have put many miles on without issues. ripped why would you say 300+ is dangerous?
Jaygo put it to stock and take it to the dealer.
i had 311whp and this weekend i noticed smoke comeing from the exhaust (not black)
rough idol and missfires like crazy...
pulled the plugs, oil one cylinder 1's plug
other cylinders look normal
strong oil buring smell at idol, and on take off
smoke only comes out on take off and after boost...
compression test:
cylinders 2,3,4 = 150
#1 = 75
FML, pretty sure its the piston rings......
compression test:
#1 = 75
On the 300whp discussion...
First, I'm not a tuner so I'm just wondering but there's plenty of people over 300whp who've been that way for quite some time (myself included) and haven't had issues. Would it be trying to run too much timing maybe having something to do with people busting rings???
I just ordered a K&N SRI and a DP and plan on a trifecta tune to hit ~300whp and now I'm slightly worried about possible problems down the road...
I know there is always warrenty but even flshing back to stock isnt always a 100% solution
From: Home: Charleston, WV / Living in:Ft. Riley, KS
I've had my tune for a little over a week...cylinder 1,3, and 4 misfires and pouring white smoke! 25psi ftl! Stock intake and chargepipe here I come! UNtuned already! wish me luck!
Yea, 25psi is known to do that. If you go over 23psi its almost expected to kill your motor
I believe hes talking about a local here in Houston that popped quite a few motors tuning. And I think he's the one that tuned Jaygo's car. On that note though every LNF(mix of Trifecta and HPT tuned cars) car I know in Houston has had new pistons or motors installed under warranty(or we put forged ones in ourselves) cause they all had ringland failures or piston issues.
ssblackstealth i had 311whp and this weekend i noticed smoke comeing from the exhaust (not black)
compression test:
#1 = 75
when i idle as well i can smell a burning smell but dont know what it is. but dont smoke after boost, well 7 psi.
also where can get a compression test done at?
i had over 300 for a long time as well guys, but it still hit me....
iv been idoling rough for about a month but thought it wasnt anything major
i did the compression test at my house lol
any auto parts store should be able to do it, it is very simple, pull ur coil packs and plugs out of all cylinders, insert the comression gauge (has a fitting on end to screw into cylinder just like spark plug), turn the motor over for about 3-4 sec's and look at the gauge.....
i couldnt tell if it was more blue or white but its def not black lol (smoke)
Last edited by ssblackstealth; Mar 21, 2011 at 10:44 AM. Reason: Automerged Doublepost
