why they didn't put a 6 speed in the TC?
I think that's my only complaint...it seems 1st is quite a bit too short in these cars. Maybe an extra gear would have helped them to space the gears out a little better....maybe not. The next question is, would we want that in a turbo car where you have a little turbo lag to deal with? Either way, 1st is over too fast IMO.
Agreed! You need to realize that GM probably did all kinds of testing to maximize the fuel efficiency with the performance...do you think they just picked the gearing ratios blindly? If there were an advantage for a 6 speed, they would have done it...
My only complaint about our transmission is the gap between 1st and 2nd. It feels like shifting from 1st to 3rd sometimes, but I guess when we get to the point of having over 300whp It wont matter anymore. It might actually help with traction.
Not completely true on a turbo car you want a slightly longer final drive to build boost. For instance my vette is N/A and nitrous assisted so I put very short 4.10 gearing this is to keep cylinder pressure from nitrous down and multiply torque. When I turbo the car I'm going to go down to a 3.08 to help build boost pressure with the big turbos. Hell lingenfelter steps it down to 2.72 for there twin gt35r setup. The same conce[t a[[lies to the SS/TC only on a smaller scale.
Wouldn't it be nice if the 5th or 6th gear was a .60 or the final drive ratio was a ~3.60.
That would put the rpms were I would rather see them on the hwy. Although changing the final drive ratio would slow the 14 mile time.
O well.... thanks the replies.
Whats the point of moving the gears close together? The whole benefit of a flat torque curve is you don't need to put the gears as close together because you wont get stuck outside the power band. Its just another shift between 0-60 or 1/4 mile which would slow the times down.
6th gear would've been really nice for highway driving. I commute on the highway everyday and I always wish it were there, but oh well. Just GM trying to save some more money, I guess.
2008 Cobalt 260 ft lbs @ 2000 rpm.
VS
My previous car (which is for sale) 2001 Camaro V6 3800 5 speed with a 3.23 rear end.
Torque 225 @ 4000 rpm. At ~68 mph it was a 2,000 rpm. (Heavier car but more aerodynamic)
My mom car is a 2007 Saab 2.0T (210 hp)
It has a 6 speed manual tranmssion and it only makes 221 ft lbs of torque @ 2500 rpm.
I don't have any rpms number at this time, she just bought it 2 weeks ago.
I will have to agreee with cost being a large factory and packaging. The saab that the 6 speed manual is a bigger car than the cobalt.
The tq curve of the the tc is much broader than the sc...most turbo cars have much taller gearing, because the longer you keep the turbo spooling full boost, the more acceleration.
There is more than power+gearing=fast.
A 6 speed in this car would be retarded, if you look at the timing tables, there is a reason why we rev where we rev at highway speeds
/end thread.
Well I understand what you are saying but how do you explain the following.
VS
VS
And completely undriveable.
/end thread.
/end thread.
I remember reading about them running the SS/TC at Laguna Seca and remarking that because of the torque (and gearing!) they were able to run most of the track in 3rd gear. All the while beating the other cars in it's class. Many of which I'm sure had to do a lot more shifting.
qft!
http://www.motortrend.com/features/p..._cooper_s.html
SS/TC - 1'47.751"
EVO X - 1'47.713"
Sl0wbaltSS
Nov 21, 2018 11:11 PM
