wrong MAF Sensor?
Old Jul 9, 2015 | 10:57 AM
ryancera24's Avatar
wrong MAF Sensor?
So this might be stupid but it's bothering me and I'm new to upgrading my car lol so here we go. I recently bought a intercooler package and it came with the charge pipes when I put everything on I noticed that the MAF Sensor that's suppose to be on the zzp charge pipe has 3 screws placement but my stock one only has 2. I still installed it but now there's 1 empty hole for a screw only half of it is showing and I'm getting a huge boost drop I think it's becouse of that hole(it probly is). Where can I buy a aftermarket maf sensor that has the 3 screws instead of 2 lol
Old Jul 9, 2015 | 11:08 AM
Axelthered05's Avatar
pic?
Old Jul 9, 2015 | 11:26 AM
sc4door's Avatar
Are you sure you aren't talking about the MAP sensor? Because if I remember correctly, the holes for the stock MAP and the 3 bar map are different and ZZP provides a set screw to plug the unused hole
Old Jul 9, 2015 | 12:03 PM
ryancera24's Avatar
Isn't that bar map on the engine? I'm talking about the cold side charge pipe
Old Jul 9, 2015 | 12:04 PM
Yeah i think hes talking about the map. Unless he had the harness to relocate the maf
Old Jul 9, 2015 | 12:30 PM
sc4door's Avatar
No, there's a MAP on the intake manifold and another on the cold side pipe. The MAF is in the intake, pre turbo.
Old Jul 10, 2015 | 02:30 AM
ryancera24's Avatar
Ok let's go with its the map sensor I never got the set of screws to cover it and would that hole reAlly be the cause of my boost drop
Old Jul 10, 2015 | 08:28 AM
sc4door's Avatar
Yes most likely. If it leaves an open hole into your charge pipe, it's a boost leak and would cause an issue. Anyway you can upload a picture and we can tell you for sure? Plus if you didn't get the screws, you could send the picture to ZZP and show them what you still need
Old Jul 10, 2015 | 08:58 AM
Are you talking about the connection point for the vacuum line to the solenoid on the intake manifold?
Like the part where the brass nipple is in this post, this also shows you the 2 different map sensors and the configurations
Originally Posted by JAYNO20
These were posted by ZZP in another thread somewhere I believe... Hope it helps...
Old Jul 10, 2015 | 09:08 AM
ryancera24's Avatar
Yea I was going to take a picture but that's the one it has 3holes but my stock has only 2
Old Jul 10, 2015 | 09:29 AM
The stock is the 2.5bar sensor with 2 screws, the open hole is for the 3bar sensor (second pic in quote). The hole should not go through the entire block of aluminum into the airflow
Old Jul 10, 2015 | 10:17 AM
ryancera24's Avatar
Haha thank you so much!!!!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
