ZZP downpipe O2 bung question
Old Jul 24, 2010 | 10:41 PM
EcotecAddict's Avatar
I'm considering getting the ZZP catted downpipe and was wondering where the O2 bung is located and what it looks like. I've seen a few pictures floating around in the forums, some showing an angled short tube close to the resonator end (running stock exhaust) and others showing a long L-shaped tube a little closer to the manifold end. Anyone have an idea which it is?
Old Jul 24, 2010 | 10:45 PM
DavidW's Avatar
i have the spun metal cat one, i just got it, it has the one that comes off, then takes a 90 degree bend, that probably the L you speak of
Old Jul 24, 2010 | 10:49 PM
09CobaltSS1's Avatar
It's sort of more like a "J" than an "L" but yeah basically the same idea... It is located about 8"-10" before the flange where it meets up with the rest of the exhaust if I remember correctly. It's basically in the stock location, just with a defouler ("J" looking thing) on it
Old Jul 25, 2010 | 12:32 AM
Does that cause any problems having the sensor that far away from the exhaust flow? I noticed that a lot of the other downpipes have a shorter angled tube.
Old Jul 25, 2010 | 12:34 AM
Zander916's Avatar
Like the other guy, I have ZZP's spun metal cat downpipe. Wow I'm not sure how many miles it's been on now. I drive a lot.... (I'm at almost 53K miles on my 08) I calculate 10-12K miles minimum that mine has been on. Not a single issue thus far. It's been flawless.
Old Jul 25, 2010 | 04:27 AM
SSlobalt's Avatar
The farther away, the better. This post-cat O2 sensor's only function is to detect a faulty cat. Picture of buddy's ZZP DP.
Old Jul 25, 2010 | 03:50 PM
^^^Thanks, that's exactly what I was looking for. As long as it doesn't throw any CEL's that's the one I'm going with.
Old Jul 26, 2010 | 10:18 AM
SSlobalt's Avatar
My buddy Drew has thrown 2 CELs in the past 4 months, but one time he stalled taking off and it came on. You just disconnect the battery and clear the code. No biggy.
Old Jul 26, 2010 | 11:20 AM
importkiller's Avatar
I got one check engine light while on while using the stock tune. I have never had one on my hpt tune.
Old Jul 26, 2010 | 11:49 AM
northvibe's Avatar
I hate when people say that. If you have a hpt or trifecta you better not throw a cel, it can be disabled!! so it shouldnt.
Theres a friend in MN with a catless and is throwing codes with a stage 1 gm tune. Otherwise I have a catted hahn and havent thrown a code. if you go catted you have a much better chance of not throwing a code.
Old Jul 26, 2010 | 12:06 PM
Zander916's Avatar
I went with a ZZP spun metal cat. No codes yet after 10-15K miles on canned tune.
The power difference is very very small according to what I've researched. It's really about the sound I think and the catted is plenty loud for me.
Old Jul 26, 2010 | 12:11 PM
chevysssc's Avatar
im thinking a byt tune might be in the future btw when are u headin up
Old Jul 26, 2010 | 02:12 PM
efactor's Avatar
****.. I ran my ZZP 3" catless for about a month with the J shape bung without throwing a code or engine light with GMS1. What is there to be scared of?
here is a pic of what my o2 sensor looked like on the stock DP before I put it on the catless DP.
Old Jul 26, 2010 | 02:37 PM
northvibe's Avatar
ya thats why I went catted. Not much power loss compared to catless, little quieter and most likely not the hassle of a cel on a gm tune.
the annoyingness of a cel on a gm tune is the 1 part. Not every car acts the same, its very random with catless.
Old Jul 29, 2010 | 12:50 AM
DavidW's Avatar
I am throwing the slow to respond code with my spun metal zzp
Old Aug 31, 2010 | 06:42 PM
HHRSSouth's Avatar
My ZZP spun metal cat DP did this also. I had them disabled by Vince in my Trifecta tune.
Here's the kicker though, my ZZP catless DP never threw a code (and I still had the codes enabled), I only threw a code after I swapped to the spun metal DP.
Yes, I did make sure the wires were not twisted or pinched on my O2 sensor when installed on the Spun metal cat DP. Everything on the O2 wiring harness connector down to the sensor looked almost new. I only had 5,500 miles total on my car, so I highly doubt the O2 sensor went out.
Old Sep 1, 2010 | 12:00 PM
Lytle_SS's Avatar
Same, just installed the ZZP catted DP and I am throwing a CEL. I threw it only after 15 miles of install then I cleared and it took longer to throw it the second time. I am trifecta tuned, but I tuned the car before the downpipe install so I didn't have it programmed for the DP.
Some people on the site say that the code isn't thrown as much, the longer you drive with the DP.
It's just wierd that some people throw a CEL and others don't.
Old Sep 1, 2010 | 10:27 PM
SSlobalt's Avatar
Consensus is that the sample tube on the ZZP pipe is a little too long, causing the slow to respond code.
Old Sep 1, 2010 | 10:35 PM
DavidW's Avatar
and if you try and get help from zzp on it, they say your **** out of luck,
I contemplated gutting the cat, but i dont wanna risk the cat inefficiency code
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
