ZZP LNF Turbo Upgrade- First Dyno Session
#327
another curious point.
are you guys logging fuel pressure? at least for your own internal use? durring the pulls?
at that pressure, does it remain fairly linear?
#329
I got back on the dyno tonight. Just for you guys, I did a pull going WOT at like 10 mph in 5th gear. Well, not really, but it felt like it.
3rd gear 2000 rpm to 7800 rpm with boost peaking at 25.5 psi. ECM closed the throttle at 7600.
Turbo is fully spooled at 3800 RPM.
#337
No, it's nothing like that.
thanks!!!
are you guys logging fuel pressure? at least for your own internal use? during the pulls.
at that max pressure, does it remain fairly linear?
#342
Matt will be having a 30R to compare to soon. I will hopefully be up there to get my valve springs installed in the near future.
#344
http://sites.commercecreators.com/fo.../zzplnf510.bmp
#345
How can a thread about a turbo upgrade and a solution to raise the power limit of the LNF by 25% can turn into a bitching fest and dyno theory argumentation ??
Anyway, it's awesome that a vendor finally has a solution for those seeking big hp numbers. It's also very interesting that the LNF can spool that turbo in the mid 3k rpm and have a 4k rpm power band.
wow, I'm very impressed.
and zoomer please get me and 06black straight lol.
And thanks for the the new dyno sheet, I likes.
Last edited by 06blackg85ss; 10-30-2009 at 06:28 AM. Reason: Automerged Doublepost
#348
With a mysterious fueling solution that you can't talk about?? Just like the mysterious trans-axle fix to get it to hold more power ?
Awesome power curve by the way.
