zzp lnf upgrade kit
Old Apr 4, 2012 | 02:57 PM
slobalt22's Avatar
zzp lnf upgrade kit
going to purchse the kit next week, but cant get ahold of zzp for some questions hopefully you guys can help me out.
my car just got a new stock clutch and trans put in this week from dealer, do I need to upgrade the clutch to handle this kit?
is it safe to go with the two bigger turbos on the stock motor? or does it require additional mods to work safely with those?
tuning...can trifecta do that for me like they do with can tunes or no? where should I go with that...
only things I can think of right now, if any of you have done this before and have any pointers for me, id appreciate it. thanks.
Old Apr 4, 2012 | 03:06 PM
EXsoccer1921's Avatar
you aren't going with two bigger turbos...
Old Apr 4, 2012 | 03:09 PM
matt638's Avatar
its a single turbo upgrade
Old Apr 4, 2012 | 03:14 PM
slobalt22's Avatar
lol i mean the s252, s256, or s259....no a twin turbo setup lol
Old Apr 4, 2012 | 03:16 PM
jg707's Avatar
i think there are two different options zzp offers to upgrade to, the s252 and s256?? i think this is what he meant by the two bigger turbos
Old Apr 4, 2012 | 03:19 PM
NME's Avatar
NME
They answer emails with in the day typically
Old Apr 4, 2012 | 03:20 PM
jg707's Avatar
i didn't have a question.....i was just trying to clear up some confusion...
Old Apr 4, 2012 | 03:44 PM
tomj77's Avatar
Yes alot of people have done this kit, yes u will need a upgraded clutch, yes u can run it on stock motor, stock motor can handle 450whp to be safe, shoot for 400 whp
Old Apr 4, 2012 | 03:51 PM
paintballerr78's Avatar
You may not need a new clutch ive been running around 400+hp for a couple months on my car no clutch slip yet*knock on wood* far as a tune id go with hp tune and not trifecta. Zzp can send you a canned tune or you can find a local tuner and have them tune it
Old Apr 4, 2012 | 04:05 PM
FasterIsBetter's Avatar
I'd get a tune from ZZP. The reason my motor blew a headgasket was the factory boost controller was routed as a manual boost controller on the tial wg and it caused rapid surging. It was because I went with Tials WG diagram on their site, when I should have asked zzp for one. So yeah, an S256ET is safe. Now an S259 is pushing the stock bottom end. I would personally get a clutch, you can get the KY 6-Pucks for around $475 and from what I hear, they're a great clutch.
Old Apr 4, 2012 | 04:48 PM
Matt M's Avatar
If you are going to run the stock clutch, I would go with a 256 and manual boost control. When the running the 256 at ~20psi, the boost will climb a little with RPMs. This will keep the torque low for the stock clutch, but you will still have to be careful. When you put in a stronger clutch, then you can turn it up to 24psi and pick up a bunch of power.
Don't run the 259. They have a power band like a sterotype Supra, except you can't rev high enough on the stock valvetrain. With stock springs, you will have no bottom end due to the turbo size, and no top end due to the valvesprings.
I can set you up with an ECM that will work well without additional tuning. You can email me at stattama@aol.com with any questions.
Old Apr 4, 2012 | 05:29 PM
slobalt22's Avatar
thanks man, ill shoot you an email now.
Old Apr 4, 2012 | 05:48 PM
matt638's Avatar
ahaha alright
Old Apr 4, 2012 | 08:54 PM
tomj77's Avatar
hahaha i love the stereotype supra's, u take them for the first second or 2, then u hear a masive turbo spooling behind u and a blur as it rockets past u tirers screaming. lol so funny. so ya it tells u when ur about to get creamed.
Old Apr 4, 2012 | 10:05 PM
raver0789's Avatar
Matt M - I bought an ecm tune from you with my s256et kit. Should I have gotten a manual boost controller. I was planning to alter the ecm tune to run 26psi of boost if its possible. Wasn't sure if the ecm would allow me to run that much power. Cheers.
Old Apr 4, 2012 | 10:52 PM
Matt M's Avatar
How long ago did you get the ECM from us? If it is fairly recent, then you can run a manual boost controller without issue. Otherwise I can update you to a better MBC file or help set up your file to run the boost levels you are looking for.
Old Apr 4, 2012 | 11:47 PM
raver0789's Avatar
I ordered your kit 4 weeks ago. I haven't gotten aroind to assembling it until this past weekend and I am not finished. I will email you tomorrow if I get a chance.
Old Apr 5, 2012 | 01:35 AM
Not trying to take away from ZZP's business or anything, but treadstone has almost the exact same manual boost controller that ZZP uses for $60 on their site. Its the one I'll be using.
Old Apr 5, 2012 | 02:53 AM
raver0789's Avatar
I like the looks of the AEM unit. I am shopping though, and think i will stay with an ecu tune for now. The plan is once I get a built motor trans and the fifth injector with e85, that i will need a boost controller with limits around 35psi.
Old Apr 5, 2012 | 11:55 AM
Yeap, hoping to get a built trans and fifth injector+aeromotive stealth as well. Not going to worry about the fifth injector too soon though as I have my meth kit to run later. I got the manual boost controller so when my engine is broke in I can get a retune and crank up the boost when I want to.
Old Apr 5, 2012 | 12:25 PM
slobalt22's Avatar
gotta call from them today, shooting for 450 with no meth. gotta say i cant sit still im so excited lol.
Old Apr 5, 2012 | 12:47 PM
Did you go ahead and order it? You're going with the stage 3 kit right? You should cruise up with me to their dyno meet. You can get dynoed there and see what you're making depending on if they get it to you quick enough since the meet is this month. I'm hoping to get dyno tuned up there.
Old Apr 5, 2012 | 12:58 PM
slobalt22's Avatar
wont have it fast enough, it'll be 2 weeks, ordering the kit next tues.
Old Apr 5, 2012 | 01:09 PM
Frogstofall's Avatar
Dyno tuning is a pretty involved and long process (most of the time). Do you think that the meet would be good for that? Seems like Matt's attention will be so scattered. I guess they could use your car as the teaching / demo subject for the tuning "class" they are planning for Saturday.
Old Apr 5, 2012 | 01:15 PM
Not necessarily. They do have two days dedicated to tuning and stuff. I could atleast learn how to tune the LNF myself as I am not familiar with F/I applications when tuning or specific tables that the LNF has.
I mean, I have messed around with the wg duty cycle by dropping it to save my stock clutch some but thats about it. I was too scared to mess with anything else significant.
