ZZP PCM vs GMS1 Question
Old May 2, 2014 | 06:16 PM
QuickSilver_SS's Avatar
Originally Posted by Cobalt_Daddy
the canned tune doesn't require GMS1 tune as a base.
my GMS1 will break the tires loose from a roll if the pavement is slippery or smooth. usually it hooks up fine though.
ZZP LNF Turbo PCM:
•Raised rev limiter to 7000
•WOT fueling is revamped to provide a safe, flat air/fuel ratio at all RPMs
•Works with high flow cats, 420 code removed
•Torque abuse modes are modified to eliminate bog during WOT
•boost set to 22 PSI
•Cam phasing adjustments for wider powerband
•Proven HP gains shown in dyno chart
•Clutch relearn complete (so you do not need to)
"The ZZP PCM is backed by a company you can trust. Here at ZZP, we own our own chassis dyno ensuring the maximum performance on our products.
With just a tune, we can add about 40whp and 80 ft lbs. Typical dyno numbers are 280whp and 320-340 ft lbs depending on what clutch the car has. If the car has a stock clutch we reduce the torque a little to keep it from slipping."
my GMS1 made almost 270whp and on one pull almost 300wtq. so the ZZP tune will make about 10whp and 20wtq more if dyno's are comparable.
You and I live fairly close to each other. I think we met a few years ago when I first bought my TC. Sense then I installed the gms1. And like you mentioned every once in a while my car will break loose in second gear from a roll. On a cold rain day like today it will ever time I floor it. But if its nice and hot out. And i go wot i would say it will only spin a tiny bit MAYBE 2 or 3 times out of ten. The other 8 or 7 times it will hook up totally. Is that consistent with your car ? My car has very low kilometers. I would hate to think that there is anything wrong with it. And ive tested for boost leaks about a million times and i cant find any leaks. Unless they are well hidden.
Old May 2, 2014 | 06:49 PM
colodude18's Avatar
Bear in mind that there are many factors affecting traction. Humidity and outside temperature, obviously, but also what tires you are running, and what suspension setup. At ~450hp my car doesn't break loose in a straight line as long as I run my properly heat cycled and warmed up NT01's and the outside temp is at least 85 degrees... Just saying.
Old May 3, 2014 | 08:00 AM
Bluekid99's Avatar
wellp it looks like ill be ordering this tune since it is way cheaper then the gms1 tune that is ridiculously high priced
Old May 3, 2014 | 08:56 AM
Piston3's Avatar
Do it. Money well spent. And if you don't buy the k&n intake with it they can update the tune later for you if you do. I think it's $75 for a tune update.
Old May 3, 2014 | 09:16 AM
Bluekid99's Avatar
I already have a k&n sri and catless downpipe so im not too concerned with that...just gotta rip out my pcm...how long does it usually take to get done and get back?
Old May 3, 2014 | 12:04 PM
colodude18's Avatar
The have a core option where you get the new one first and send in yours later for a refund
Old May 3, 2014 | 12:24 PM
Bluekid99's Avatar
does gm need to reflash it in order to run or just plug and play
Old May 3, 2014 | 12:45 PM
colodude18's Avatar
I believe they include the clutch relearn now so it would be plug and play. Regardless, clutch relearn can be done by anyone, no need to go see the dealership
Old May 3, 2014 | 03:01 PM
Bluekid99's Avatar
will the gm 3 bar make any difference with this tune?
Old May 3, 2014 | 07:07 PM
colodude18's Avatar
Not sure; that's a question for ZZP
Old May 3, 2014 | 10:21 PM
  #36
m33pm33p's Avatar
7000 rpm redline on stock turbo... useless except for 3rd gear at a drag strip.
Old May 3, 2014 | 10:33 PM
  #37
Piston3's Avatar
I agree. I think the idea is keeping you from bouncing off the rev limiter. I really don't see any point revving past the stock limit. There's just nothing there.
Old May 5, 2014 | 06:09 AM
  #38
Cobalt_Daddy's Avatar
naw it's not consistant man. it really depends on the road surface as to whether or not it will break loose.
usually if i go WOT in 2nd it will chirp and go.
Old May 5, 2014 | 06:10 AM
  #39
from what i understand the 3 bar sensors will only help read correctly on the guages.. you can still do the tune without them.
Old May 5, 2014 | 01:43 PM
  #40
Bluekid99's Avatar
does this tune disable learn down feature or no?
Old May 5, 2014 | 02:02 PM
  #41
I would think it does. But there has always been some conflicting information whether or not gms1 disables the learn down. Every time i read about it , someone is saying yes. While someone else says no. Lol
Old May 5, 2014 | 03:22 PM
  #42
Bluekid99's Avatar
pretty much just install and figure out lol
Old May 6, 2014 | 11:15 PM
  #43
BoostinBALT32's Avatar
I installed my today it took less than five minutes to install and then the relearn. It made a huge difference over stock I've got a catless do K&N short ram and charge pipes it spools quicker gets up and goes I have the first gear reduction I love it and for 130 dollars I couldn't go wrong not 510 like gms1
Old May 7, 2014 | 06:57 PM
  #44
heeter_33's Avatar
I think I might go this route. What software do they tune with?
Old May 7, 2014 | 11:23 PM
  #45
HP tuners. I just had my car at ZZP on Monday to get dyno tuned.
Old May 7, 2014 | 11:45 PM
  #46
Piston3's Avatar
What a tease! Give us the numbers!
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
