zzp rotated trans mounts vs ottp
Old Mar 9, 2014 | 09:35 PM
tomj77's Avatar
so which is better and why? I have ottp right now, dash vibrates when I start driving. I heard zzp doesn't do that. but other than that is there any difference? would it be a good idea to switch over to zzp or just stay with ottp
Old Mar 9, 2014 | 09:38 PM
sl0wlsj's Avatar
ZZP mounts definitely make your car vibrate too! I had ZZP mounts but never OTTP.
Old Mar 9, 2014 | 10:52 PM
They all vibrate more than stock, price you pay for stiffer mounts
Old Mar 9, 2014 | 10:58 PM
bdubs04's Avatar
I have zzp and vibrations during idle, but no vibes while in gear driving. Had polyurethane mounts before and they were bad on vibration, thought the car was going to shake apart
Old Mar 9, 2014 | 11:13 PM
andrewcarr1993's Avatar
I have a Powell front mount with an LNF rear mount and I don't think it's that bad. Definately noticable when idling and whenever you rev it out of gear (think downshifts you can feel it rev). I wouldn't go from OTTP to ZZP though because the OTTP mounts are rotated and the ZZP mounts aren't. Really the best mounts are the Powell ones though.
Old Mar 9, 2014 | 11:19 PM
gmlifestyle's Avatar
What about torque solutions from modern performance? They any good? pros? Cons? Is zzp best bang for buck?
Old Mar 9, 2014 | 11:22 PM
Powell is best bang for the buck
Old Mar 9, 2014 | 11:40 PM
AARON-SS-TC's Avatar
Why is this in the performance section?
It should be in the suspension or general tc section.
Btw, any rotated mount is good, ZZP HAS LESS VIBRATION THAN OTHERS.
Old Mar 10, 2014 | 12:18 AM
tomj77's Avatar
cause they help with performance lol
Old Mar 10, 2014 | 12:22 AM
ZZP's mounts aren't rotated they are just stiffer bushings so if they're the softest they sell the softest aftermarket bushings that go in the factory location. Don't get me wrong I love ZZP's products but their mounts aren't worth a damn.
Old Mar 10, 2014 | 01:04 AM
kzak104's Avatar
i have zzp mounts and there definitely worth a damn, stock mounts feel like the engine is spinning underneath the hood. zzp mounts stop the engine from moving around as much, makes shifting so much nicer.
Old Mar 10, 2014 | 01:28 AM
But their so called rotated mounts aren't which is why they are the lesser of the mounts out there. Yes they still help but ones that cost just as much from Powell are going to be better since they are rotated and stiffer.
Old Mar 10, 2014 | 01:39 AM
cfsnipers's Avatar
Powell kicks ass. He personally installed mine. I have less vibration than before.
Old Mar 10, 2014 | 01:59 AM
kzak104's Avatar
i doubt that considering the guy above you said powells are stiffer than zzp... and zzps are pretty damn stiff. assuming you came from stock mounts.
and ya i dont know why zzp calls theirs rotated =\
I think he's installed lots of them, he did mine as well as control arms at the same time.
I meant that they are stiffer than stock didn't mean vs ZZP, I'll edit it (too late for thinking). They are probably about the same for stiffness.
Old Mar 10, 2014 | 12:04 PM
what about the ones from turbo-tech????
Old Mar 10, 2014 | 10:26 PM
dro-balt ss's Avatar
big deal is if you have them installed correctly, i over torqued the 3 bolts in the subframe way too much and it vibrates when on the throttle, supposed to be 37lbs
Old Mar 10, 2014 | 10:28 PM
m33pm33p's Avatar
Mine are over torqued for sure, and don't have this issue.
Old Mar 10, 2014 | 10:34 PM
i have powells, should be no vibes at all i can feel it coming from that part
Old Mar 11, 2014 | 01:23 AM
kzak104's Avatar
lol, that wont cause more vibrations, just saying.
Old Mar 11, 2014 | 07:42 AM
Staged07SS's Avatar
Administrator
Administrator
Powell Stg1 trans mount and SS/TC rear mount ftw.
Old Mar 11, 2014 | 09:48 AM
armcclure's Avatar
I have Powell rotated solid race mounts and balance shaft delete. I've given up hope of ever being anything close to rattle free. It's almost like getting a massage at idle
Old Mar 11, 2014 | 10:07 AM
Josh@ottp's Avatar
How old are the mounts? How did you torque them down?
Old Mar 11, 2014 | 01:44 PM
tomj77's Avatar
2 years. Did then in proper sequence with motor mount loose. But I had a new engine put in since so Gm installed them second time. They just shake the dash when starting to move in first gear for a second. It not a big deal. They always did it.
Old Mar 11, 2014 | 01:52 PM
Josh@ottp's Avatar
Ok well you will want to loosen all the engine and trans mounts and torque them in sequence. Also check your rubber bushings in the mounts, the style bushing you have will fail if not installed correctly. We have changed to a different bushing since you purchased and it is an upgrade from what you currently have.
