ZZP Stage 2 came and valve springs
Old Oct 10, 2019 | 08:50 PM
That white balt's Avatar
I know there are post about them all over but nothing recent and no one ever talks about how reliable or unreliable they are. I currently have my head taken apart and I'm about to put Stage 2 cams and #82 valve springs in from ZZP. I'm just wondering if I'm going to have to worry about them going out in the next 2k miles. Iv seen things about the valve springs going bad, but nothing since zzp has changed suppliers. Hoping some of you guys can chime in
Old Oct 11, 2019 | 07:30 AM
cw383's Avatar
I've had 2 sets of cams and one set of springs over 40,000 miles ( LDK swap so new cams/swapped springs) . Only issue I ever had was broke rocker once and it scraped the cam. No fault of the cam/springs. I micropolished the lobe to the best of my ability by hand, and that was a year ago, still looks the same.
Old Oct 11, 2019 | 08:21 AM
jdbaugh1's Avatar
I have ZZP S2 LSJ blower cams and their 82# springs/titanium retainers, and I haven't had any issues yet and I rev the **** out of them.
Old Oct 14, 2019 | 06:31 PM
Finally had the time to get the springs and cams in. Was pain in the ass not having the head pulled. Had to fabricate an overhead spring compressor. None of the auto stores around me had them. Next is to drop the motor down and hopefully have enough room to put the neutral balnace shafts in and the ati damper
Old Oct 15, 2019 | 07:44 AM
jdbaugh1's Avatar
I know you probably already purchased the NBS which are pricey but I would recommend balance shaft delete instead. It makes for a more robust setup. It's advantageous because you eliminate chain driven rotating mass, which you have to rely on to stay together, and also needless stress on water pump chain.
To help install the ATI balancer I sourced a M14-1.5 X 130mm bolt through Fastenal. I also used a couple greased up washers to prevent galling the pulley. I know it may be considered taboo by some to use a bolt instead of a stud but this bolt provides sufficient thread engagement IMO. Alternatively you could source some M14-1.5 all thread.
Old Oct 15, 2019 | 10:39 AM
cw383's Avatar
Let me know if you get enough room to get your balance shafts out? To do the ATI you need to undo your passenger side motor mount and the 3 bolts that hold the rear transmission mount to the transmission. That gives you just enough room. Just the side engine mount wont quite do it. Dont forget to put black RTV in your damper keyway and on the back of your NEW bolt washer : ).
Old Oct 15, 2019 | 01:29 PM
jdbaugh1's Avatar
Hell I have never done this though it makes sense why you would. I probably have enough red loctite squeeze out from the crank bolt to keep it from seeping. That or the clearance is tight enough it doesn't allow the oil to make it's way through anyway because I've never had any leaks. The stock crank is the same way and without RTV from factory isn't it?
Old Oct 15, 2019 | 02:12 PM
cw383's Avatar
Its hit or miss. The last time I pulled my bolt it had some oil behind it.
Old Oct 15, 2019 | 06:58 PM
I was thinking about the delete but iv heard a lot of good and bad about it. I already recieved the ones from zzp so I think I'm going to stick with them and see how they work for me
Old Oct 16, 2019 | 08:49 AM
jdbaugh1's Avatar
You've heard bad things about the delete? I don't see the NBS having a single advantage other than it may be easier to install.
sS07NA
May 24, 2018 09:44 AM
goeckeritz123
Apr 14, 2014 05:28 PM
Blitz19
Jul 7, 2013 10:29 PM
LE5
Jan 12, 2012 04:39 AM
jdgpuller
Jul 28, 2011 06:52 PM
