02 sensor differences
What is the difference between the 02 sensor in the header and the 02 sensor after the cat? Other then the female and male ends. Thanks
Reason for this is because Im getting HORRIBLE mpgs and now have an check engine light p1133 for heated 02 sensor. I have 2 02 sensors laying around thats for the after cat sensor. So my question is, can I use the back sensor for the header sensor??
Thanks
Thanks
if that was true you would be able to use a o2 from any car and you cant there is some differences between pre cat and post cat o2 sensors and differences between car makers and and models
Sl0wbaltSS
Nov 21, 2018 11:11 PM
