05 turbo swap
No idea not enough information there and most likely not. Either a new kit would have to be bought or a custom job would have to be done. Honestly if your looking at going that route check out BYT 5k kit with a EFR turbo.
What? The exhaust manifold flange is exactly the same between the two cars. If its a top mount or a log there a tiny chance you would run into fire wall clearance. Is it the hahn kit with an 16g turbo? If so ask hahn in an email if it will fit. Besides that the charge pipes and inlet pipe to the turbo will need to be modified.
ThoR294
Oct 4, 2015 08:44 PM
