06 ss loosing 3lbs of boost
Old Feb 1, 2010 | 11:02 AM
teampruven's Avatar
my car ran a consistant 12lbs of boost. i put on an intake and now when i get up around 4500rpm's or higher my boost falls down to about 9-10. it never did that it was always consistant. i checked for leaks but don't believe i have one anywhere. anyone have a similar problem with an intake install? i got a check light a few days after putting it on. i disconnected the battery for a bit and cleared that. but how would it make me loose boost. some help
Old Feb 1, 2010 | 11:11 AM
scotch89's Avatar
humm thats wierd....im always around 10 pounds, and if im lucky ill hit 12. im sitting at 7k on elavation. what about u?
Old Feb 1, 2010 | 12:30 PM
teampruven's Avatar
i have no idea on elevation. and someone last night told me on here to disconnect my battery and i did. so now the code is cleared and i can't pull it to even know what it was.. i'm 99.9% it is intake related since i just put a new one on a couple days ago. i'm sure the light will come back on again. i checked and have no leaks.. the throttle seems a little jerky at lower rpm's.idles fine. once i'm in boost its fine besides loosing a few lbs at high rpms which my mechanic told me is actually quite normal on a sc car. but it didn't do it before the intake. i had some ******* say send your intake back but...i don't think the manufacture of it would make a difference.. its a piece of pipe. wether or not it has to learn the new air flow i dunno. i've always had fords.
turbochargedss2012
Sep 20, 2023 12:17 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
Tupp
Sep 30, 2015 08:18 PM
jmelton327
Sep 26, 2015 10:04 PM
