07 lsj e85 questions
Old Aug 12, 2012 | 11:16 AM
spd4lifess/sc07's Avatar
Talking 07 lsj e85 questions
So i have been looking to jump on the "e wagon" with my balt, but i have questions that i have not really found answers to. I have read ebristol's threads and others on e85 and have seen good results so i am thinking its time to do it.
my mods right now are gm stage 2, option b, dual pass, smoothflow 2.9 pulley, stock air box filter mod, fuel pump rewire, zzp phenolic intake spacer, badmab shorty header, zzp 2.5 catless down pipe bolted to stock exhaust, hptuners pro, and lc-1 wideband.
future mods to be decided, bigger heat exchanger, larger injectors 60's/80's(i am looking at 80's for growth), smaller pulley 2.8/2.7, and clutch.
1. what do most people find to be the sweet spot for hp, mpg, and engine life, straight e85 or e47 blend?
I have e85 pump and 93e10 nearby so I can blend 1:1.
2. should i upgrade to a better fuel pump if i run 80's on e85/e47 blend?
have 28k on my stock pump.
that's it for now if I think of any other questions(that i don't find on my own) i will ask.
thanks for your time
-Joe
Old Aug 12, 2012 | 11:19 AM
kdub1492's Avatar
Yes upgrade your fuel pump and get some 80's. If you read up you will see that people are making about the same power with an e47 blend as they are with an e85 full tune. I run an e47 blend, but will run 93 in the winter, just because e85 fluctuates in the winter here in Illinois
Old Aug 12, 2012 | 11:25 AM
BLAZIN07SS's Avatar
I'm too JDM for you
Fuel pump doesn't need to be touched. Just bigger injectors and tune for the basic mods you have.
Old Aug 12, 2012 | 11:32 AM
kdub1492's Avatar
It's known to go out, I'm a person who takes precaution haha. But yes you don't need to change it
Old Aug 12, 2012 | 01:00 PM
BLAZIN07SS's Avatar
I'm too JDM for you
05 pumps are known to go out. 06 and 07 pumps are fine
Old Aug 12, 2012 | 01:04 PM
carstedt's Avatar
you dont have to upgrade your fuel pump i still have stock pump in my car lol...never got around to puttin in my new one lol
Old Aug 12, 2012 | 01:35 PM
whats the e47 blend mean? i have 1 station near me with e-85...
Old Aug 12, 2012 | 01:43 PM
carstedt's Avatar
e47 is a mix of pump and e85
Old Aug 12, 2012 | 01:53 PM
kdub1492's Avatar
e47 is a 1:1 of e85 and 93
Old Aug 12, 2012 | 04:05 PM
yeah i have read the 05 pumps are weak, but just wanted to make sure.
Old Aug 12, 2012 | 04:09 PM
cbro's Avatar
i run 80s injectors and 2.7 pulley on e85, it runs great. just shy of 300 whp. on stock pump by the way have have ran this setup for more than a year through winter and everything, and haven't had one problem.
Old Aug 12, 2012 | 05:50 PM
cool i thought it was a mix just wasn't sure... whats the point of doing a 1:1 mix vs full e? is there a chance of detonation doing full e or something
Old Aug 20, 2012 | 12:48 PM
ebristol's Avatar
Better fuel economy with all the power of E85.
On average I get 19mpg with E85. But that is will a mix of city and country. On the highway, I get 22-23mg if I ***** foot it.
Old Aug 20, 2012 | 02:11 PM
Tjolley's Avatar
-Joe
im a 2007 ss sc on e85 with a 2.8 and 60# and nos...with a idc of 95% @ 7500 rpm
my car idles better than stock with the a/c on or off.
Old Aug 20, 2012 | 02:13 PM
Tjolley's Avatar
and my cold starts are almost normal..a lil sputtered for a split second and then it idle perfectly fine
Old Aug 20, 2012 | 02:23 PM
carstedt's Avatar
my cold starts used to suck...once in awhile it took a 2 turns of the key to start..but before i left it was actually really good..started right up and idled fine
Old Aug 21, 2012 | 01:28 AM
cbro's Avatar
what pulley and injectors do you have?
Old Aug 21, 2012 | 11:11 AM
ebristol's Avatar
I am running a TVS with a 2.7" pulley, 80# injectors with an OTTP RSFS with the base pressure set at 50 psi.
The RSFS allows me to lower the fuel pressure for more precise fueling under light loads.
80s Idle - YouTube
The secret to getting better fuel economy with E85 is to add timing in the timing table where the car cruises.
Old Aug 21, 2012 | 11:24 AM
cbro's Avatar
oh okay, i have 2.7 and 80s on m62 and i get like 17-18 in city. not quite sure on highway.
also on e85
Old Aug 21, 2012 | 11:45 PM
Tjolley's Avatar
https://www.youtube.com/watch?v=dMiZ...e_gdata_player
Old Aug 22, 2012 | 09:22 AM
armcclure's Avatar
25mpg highway with a 2.6 m62 and id1000's....
Old Aug 22, 2012 | 09:39 AM
jp1600's Avatar
My car = 80s and 2.8 with e85, my car also = 28mph average, area 47 rules
Old Aug 22, 2012 | 09:45 AM
carstedt's Avatar
wut is ur mod list that ur running 1000's with the m62 if u dont mind me asking
Old Aug 22, 2012 | 09:49 AM
jonathan923's Avatar
cars like the lnf run through fuel cut on high rpms if they just use E85 only. which is why they mix it
Old Aug 22, 2012 | 09:58 AM
BLAZIN07SS's Avatar
I'm too JDM for you
i get like 17-18mpg in the city, 22 highway if i baby it. thats not off the DIC, just calculating off of fill ups
