07 lsj e85 questions
Old Aug 22, 2012 | 10:33 AM
armcclure's Avatar
Originally Posted by carstedt
wut is ur mod list that ur running 1000's with the m62 if u dont mind me asking
Ls4, fully ported blower, ported head, 82# springs, zzp stg2 cams, longtube, 3" catless.
Idc 80+% @ 7500.
Idk how that guy above is possibly running a 2.8 w/ 60's on e85 without going incredibly lean...
Id1000's were necessary for the build in progress.
Old Aug 22, 2012 | 10:40 AM
carstedt's Avatar
u couldnt get away with running 80's and a refrenced fuel system?
Old Aug 22, 2012 | 11:14 AM
armcclure's Avatar
No. I forgot to mention that. I already have a return style brfps. Multiple ppl are maxing out 80's on tvs setups only reving to 7500. I'll be shifting at 8500 with an overdrive crank pulley. 80's would fall far short espicially when inload up the e98 for dyno-ing.
Old Aug 22, 2012 | 11:21 AM
Chevycobaltss3's Avatar
Hey my car gets high 30s mpg hwy based on my dic but once calculated though the actual miles and gallons used i get 24-26 most! Only way a lsj is gonna get higher mpg is leaning it and increasing cruise timing to a damn good amount! And you still shouldnt be able to reach higher 28s (itll be difficult)
Old Aug 22, 2012 | 01:06 PM
ebristol's Avatar
Originally Posted by jp1600
My car = 80s and 2.8 with e85, my car also = 28mph average, area 47 rules
I am calling BS.
Exactly.
Its not possible. I would call BS on armcclure too but he does not know how to take constructive criticism and will probably blow off the handle!
lol
Old Aug 22, 2012 | 01:23 PM
InfraRedline's Avatar
I usually get 18-20mpg in town. Occasionally Ill get 21. On the highway its usually 23 or so, but I dont take many trips so I dont have a real solid average. I did manage to get 27mpg once coming back from a car show in Minneapolis this spring though after my stock fuel pump died
Old Aug 22, 2012 | 01:34 PM
armcclure's Avatar
SHUT UP ERIC!!!
Id injectors have some of the best spray patterns available. Using a brfps allows better control at lower idc's like you said. And teh math don't lie!!!!
Old Aug 22, 2012 | 02:09 PM
ebristol's Avatar
SHUT UP ERIC!!!
Of course. Whatever you run on your car is the best...
Old Aug 22, 2012 | 02:48 PM
If going down hill counts I can get unlimited mpg if I turn the car off but leave it in koeo . If I go by my dic it says 99.99. So I can actually get 100+mpg haha ..
Old Aug 22, 2012 | 03:20 PM
nhanson's Avatar
Infinity MPG!
Old Aug 22, 2012 | 03:36 PM
  #36
armcclure's Avatar
Naturally
Old Aug 22, 2012 | 07:07 PM
  #37
Tjolley's Avatar
Idc 80+% @ 7500.
a 2.8 maxes out my 60#s wen i bring the nos in..other wise my idc is like 85-90% @7500
Old Aug 22, 2012 | 07:09 PM
  #38
carstedt's Avatar
for the build in progress i can see 1000's but for the current setup it seems as if 80's would do..but idk im only looking at it from an outside view
Old Aug 23, 2012 | 09:08 AM
  #39
armcclure's Avatar
Yes they probably would have. I just knew that my goals would eventually pass them. That's whi i went straight to the 1000's. No need to spend the money twice.
Old Aug 23, 2012 | 09:26 AM
  #40
BLAZIN07SS's Avatar
I'm too JDM for you
I am running a TVS with a 2.7" pulley, 80# injectors with an OTTP RSFS with the base pressure set at 50 psi.
The RSFS allows me to lower the fuel pressure for more precise fueling under light loads.
80s Idle - YouTube
The secret to getting better fuel economy with E85 is to add timing in the timing table where the car cruises.
Cobalt idle ID1000cc - YouTube
ID1000's idle like butter
Old Aug 23, 2012 | 10:23 AM
  #41
ebristol's Avatar
That is pretty good too.
What do those injectors go for these days?
Old Aug 23, 2012 | 10:30 AM
  #42
BLAZIN07SS's Avatar
I'm too JDM for you
i got an insane deal on them used from an ariel atom guy. $350 with everything and they had 2000 miles on them
Old Aug 23, 2012 | 01:54 PM
  #43
armcclure's Avatar
Daaang. That's a steal!
Old Aug 23, 2012 | 10:12 PM
  #44
jp1600's Avatar
I am calling BS.
Exactly.
lol
ok, you might be right, checked my interceptor instead and im at 25... now im sad, but i guess i could be worse! I would like to as well "blow off the handle" but im online, i find it wouldn't do much, lets just say i punched a baby!
Old Aug 23, 2012 | 10:20 PM
  #45
carstedt's Avatar
18-20 city...mid 20's on the freeway
Old Nov 12, 2012 | 11:04 PM
  #46
07blown's Avatar
What mods would I need to get tuned to e85 only reason I would do it is because the gallon is cheaper. I'm stock lsj sc
Old Nov 13, 2012 | 09:03 AM
  #47
ThexGovenor's Avatar
This might help: https://www.cobaltss.net/forums/2-0l...sticky-286997/
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
Builttss
Oct 4, 2015 10:21 AM
Sep 28, 2015 12:51 PM
