10w Oil Question
Old Feb 16, 2008 | 03:11 PM
BakNBlack's Avatar
10w Oil Question
Hey People Its Time For An Oil Change Again And I Have Some 10w30 I Can Get For Like 1.50 A Qt. And Yes It Is Mobile 1. Question Is, Is 10w Ok To Run In Our Cars? Or Do I Need To Forget About It, Stop Being Cheap And Pay Full Price For 5w?
Old Feb 16, 2008 | 03:12 PM
SilverBalt's Avatar
considering the oil cap on your engine says synthetic 5w30 only, i would say dont be a cheap ass
Old Feb 16, 2008 | 03:14 PM
Enuff_Said's Avatar
X2...
Old Feb 16, 2008 | 03:18 PM
BakNBlack's Avatar
it also says mobil one, but i am sure another brand wouldnt hurt it
Old Feb 16, 2008 | 03:23 PM
chevysssc's Avatar
5w-30 syn. is what you need to use you can use another brand but use only a 5w-30 syn.
Old Feb 16, 2008 | 03:25 PM
BakNBlack's Avatar
ok, thats what i figured. i have heard of car owners using 5w in a 10v car, so thought i would ask
Old Feb 16, 2008 | 03:32 PM
Sharkey's Avatar
stick to 5w30 unless you live in a very warm climate. if its hot all the time, you can run 10w30.
Old Feb 16, 2008 | 03:35 PM
Onyxd04Redline's Avatar
Royal Purple, Amsoil, Redline > Mobil 1
Pick one of the first 3
Old Feb 16, 2008 | 04:46 PM
suprchged's Avatar
Agreed RP is the ****
Old Feb 17, 2008 | 09:27 AM
2006RedCobaltSS's Avatar
I just put RP in my car last night and I really think it runs a lot better than it did with the Mobil 1. But I am comparing RP with the mobile that had 3300 miles on it.
Old Feb 17, 2008 | 01:59 PM
Before i had my 408 installed i had RP running in the LS1. After 5500 miles i checked it and it still looked clean. M1 would always get so dirty when i ran it.
Old Feb 17, 2008 | 02:12 PM
UmeNNis's Avatar
Okay people... the only difference between 10w30 and 5w30 is that at really cold temps, the viscosity is supposed to act like the weight of the first number (10, or 5). ...
What this means is, that at really cold temps (~0 deg f) the oil will be a bit thicker, therefore harder to start and circulate. While at really cold temps, this would be bad on your car, I wouldn't worry about it unless you live in a part of the country that often dips below 0 degrees and you have to start it alot in such temperatures. IE California/Nevada/Arizona etc you could run 10w30 all year without problems. But if you live in say... Minnesota, you may want to reconsider lol.
Old Feb 18, 2008 | 12:00 PM
hungryhip-ccp's Avatar
^^x2
Old Feb 18, 2008 | 07:35 PM
BakNBlack's Avatar
thanks for the info, i just went with the 5w30, but especially since we are hitting summer i might just ****** up the 10w while its here and cheap
Old Feb 18, 2008 | 08:01 PM
zinner's Avatar
Moderator Alumni
I wouldn't risk it. I guess the risk is your engine blows up (not necessarily because of the oil) and your warranty claim gets denied because of the wrong oil.
Old Feb 18, 2008 | 11:16 PM
UmeNNis's Avatar
impossible to prove that you have 10w instead of 5w in.
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
