110 octane Baby
Old Oct 12, 2005 | 10:33 AM
superbooster's Avatar
Question 110 octane Baby
I just put 110 octane fuel in my car yesterday, it runs a higher boost and it pulls a little harder. i was wondering what the implications would be to doing this often. is it a good or bad thing for your engine overall?
Old Oct 12, 2005 | 10:39 AM
3fo893013L's Avatar
You will screw your cat up quicker. Our cars aren't meant to run on this octane.
Old Oct 12, 2005 | 11:02 AM
num482's Avatar
only if its leaded.
Old Oct 12, 2005 | 11:28 PM
Halfcent's Avatar
I'm old school
Originally Posted by num482
only if its leaded.
Exactly. You will experience lead fouling and screw up your plugs and valves. And it probably isn't street legal anyway.
Old Oct 13, 2005 | 12:37 AM
GeoChevyCobalt's Avatar
It would depend on if it is leaded or not. If it is not then it should be OK depending on if it has methanol, MMT in it or not. Bottom line is to know what is in that gas before you put it in your car....
Old Oct 13, 2005 | 01:53 AM
97cavie24ls's Avatar
i use 101 mixed with the 91 we have here in phoeniz , my cav seams to like it better under boost
Old Oct 13, 2005 | 03:49 PM
05redlined's Avatar
110, i believe is considered low lead, my redline runs slower since i ran a half tank in it of 110 low lead, think i fouled the cat out, i need to put some sea foam in the crank case to get everything cleaned up....
06MetallicBalt
Jul 20, 2025 08:47 PM
Hugger1975
Oct 15, 2015 03:28 PM
Cptnslo
Sep 24, 2015 09:32 AM
twilson380
Sep 14, 2015 10:52 AM
