12.5psi???
Old Jun 16, 2005 | 09:50 PM
turboeco's Avatar
12.5psi???
My Bypass valve was loose and slightly moved, so I tightened the bolts back up and the boost level was diff.
After reading on the internet, I learned these are hand set by eaton and should not be moved. That explained the diff.
After inspecting a local dealers bypass and adjusting, I am now reaching 12.5psi at about 6k in third gear.
Is this right, I don't remember??? Or are you guys hitting and holding the 12.5 dash for awhile? If so, what rpm/gears are you reaching 12.5psi?
PLEASE REPLY, I really want this back to normal. I'm sure you understand how sick this makes me, lol.
-Thanks
Old Jun 16, 2005 | 10:03 PM
cobalt115's Avatar
I don't see it being a major problem. You can't always go by the guage anyways cause they aren't 100 percent accurate.
Old Jun 16, 2005 | 10:08 PM
turboeco's Avatar
Well There def. was a diff, even if the guage is inaccurate.
I was only getting 10psi, then after adjusting it would reach one line above 10psi which is 11.25.
Now I finally hit two lines above ten, which is 12.5psi. I may even go a hair over. The only thing is...I hit that just before the rev limiter, about 6k rpm.
Can someone tell when you guys reach 12.5psi, what rpm/gear? I can only get it in 3rd+, as they run longer.
Thanks, I just need to know if its back to normal or not. I feel much better when it is.
Old Jun 16, 2005 | 10:14 PM
theBLUEone's Avatar
Yea, mine reads 12.5 psi's on the guage....how many miles are on yours?
Old Jun 17, 2005 | 07:00 AM
turboeco's Avatar
1260miles...
I know you guys do reach 12.5psi, but thats not my question.
I'd like to know WHEN you guys are hitting 12.5 ???
I'm hitting it in 3rd+gear, at about 6k rpm. Should I be acheiving full boost sooner?
-Thanks
Old Jun 17, 2005 | 08:51 AM
cobalt115's Avatar
Supercharged engine curves are linear. If you look at a dyno sheet, you will the most power is made closest to the redline, that is when the s/c is making the most boost due to the fact that the engine rpm is at its highest point. Hope this helps. It seems the norm around here is 12.5-13 psi.
Old Jun 17, 2005 | 11:48 AM
b-spot's Avatar
About 70kPa for me
Old Jun 17, 2005 | 11:52 AM
seadea's Avatar
My friends dad is actually one of the people running the lordstown plant and he told me that there is something you can do to the wastegate and bypass valve to get more horse power and boost. plus i wouldnt be worried about making more boost which is what it sounds like is happening
Old Jun 17, 2005 | 03:17 PM
turboeco's Avatar
Thanks guys!
Yeah if I was making MORE boost, that wouldn't be a problem.
My problem was it was only holding 10psi til redline, then I got it up to 11.25psi.
Now I finally have it that it hits the 12.5psi, just before the rev limiter.
I forgot how it was stock, so I was just wondering if you guys acheive 12.5psi early (say 5k?) and hold it til redline??? If so what rpm do you achieve it?
Also I def. cant get it in 1st or 2nd gear, only third and up. Is that normal, or does it still seem a little off???
Old Jun 19, 2005 | 03:55 AM
Darksun's Avatar
im' hitting a little over the black line in between the 10 mark and the 15 psi mark how much psi is that because i dont know how much psi is line reresents?
Old Jun 19, 2005 | 12:47 PM
turboeco's Avatar
each dash is 1.25psi, the black dash between 10 and 15 is the 12.5psi mark.
If you are a hair over it may be 13psi.
Can you please answer this question, what gears and what rpm do you finally reach 12.5psi???
Old Jun 19, 2005 | 08:12 PM
Darksun's Avatar
first gear i hit right before the black line almost touching it .than second gear im right on the black line the rest of the gears im right after the black line to the point where i can see the neddles not on it any more. funny thing is i was bitching and moaning that i was only hitting 10 psi and i was at 1400 miles on the car then the next day boom i was hitting full boost
Old Jun 19, 2005 | 08:16 PM
Darksun's Avatar
oh yeah i'll hit 12psi in second gear at around 2500 rpms dont go past the black line untill 5400 rpms in third gear forth gear it stays past the black line the whole time
Old Jun 19, 2005 | 09:58 PM
Shermen's Avatar
How do you get up to 12 psi at 2500 rpm ? My SS S/C doesnt get up to 12 untill ridline (6500 rpm)
Old Jun 19, 2005 | 10:15 PM
MarcS's Avatar
The Stig
lol yeah how the hell are you doing that? I've gotta get way up there to get what I think is full boost.
Old Jun 19, 2005 | 10:18 PM
Darksun's Avatar
well im about to go out i'll check again to clear it up
MarcS's Avatar
The Stig
is there a way to adjust your bypass valve to allow boost in sooner than it is now?
Old Jun 19, 2005 | 10:33 PM
Darksun's Avatar
alright im a ******* it goes like this
1st to 10 psi by48oo rpms the line right before the 5 stays like that till i shift
2nd when i shift outta 1st it lands at the line right before the 5000 the boost gauge goes rights to the first line after the 10psi mark goes to the black line by the time im ready to shift at 6300 or 6400
3rd gear it goes stright past the the black line thats inbetween 10 psi and 15 psi as soon as the gear grabs at 5000 didn't have room to go to 4th hope that clears it up
Old Jun 20, 2005 | 01:25 AM
phxSS's Avatar
We're not gonna hit full boost until amost redline cuz the blowers need engine rpm to spool up.. getting 10psi at 2500rpm isn't really happening. your gage is messed up.
Old Jun 20, 2005 | 01:50 AM
Darksun's Avatar
yeah i know i changed what i said from my other post. So let me say it again i am not hitting full boost by 2500 rpms. and also on my one two shifts it varies if i shift bad the rpms drop to like 3900 and it takes the boost a little longer to hit max. but when im in third its past the 12.5 mark way before redline between 5300 and 5500 rpms. but hell i got no vids or picks so what i say means dick.
CanadianCobalt
Feb 27, 2011 06:19 PM
06blackg85ss
Aug 4, 2010 12:59 PM
skateitup53
Dec 1, 2009 07:45 PM
skateitup53
Dec 1, 2009 04:56 PM
ralliartist
Mar 13, 2008 09:28 PM
