12.9 to 13.2 possible with new upgrades?
Old Apr 9, 2011 | 05:08 PM
  #76
willdrew's Avatar
How was the issue with WOT box resolved?
Old Apr 11, 2011 | 07:46 PM
  #77
blackcobalt1986's Avatar
Old Apr 12, 2011 | 02:05 AM
  #78
ULWizSS's Avatar
Gonna have to wait for results until friday. My buddy will be shooting with a 6k camera to try and get some decent footage. I will be filming from inside the car like i always do.
Definately not as easy launching this car as it use to be but found a fix. My 2 step is set to 2k because its what worked best for me before i had the box. Its what netted me 97% rate of runing 2.0 to 2.1 60ft consistantly. Before i lowered my max boost 1st gear i was not able to keep my foot floored without having to feather the gas due to spinning. Now thats i lowered it from 4k to 5k range seems to allows me to run it the way i use too.
Should be interesting.
Old Apr 13, 2011 | 12:53 PM
  #79
ULWizSS's Avatar
Well since my rims where on national backorder or some garbage I decided to go to a local speedshop to have them order a set and slap my slicks on. They are going to be ready tomorrow at noon sometime.
BYT is unfortunately booked until my appointment on the 30th and cant shave the calipers down in time. Will most likely do this myself tomorrow if i can find someone that has the tool to do it. He is also hooking up the meth and tuning it as well that day.
Going to run the car tomorrow the way it sits at Atco. Hoping to run it on the slicks but will make a few passes on street tires if it dont work out with shaving them down.
I guess the goal is to break a 13.125 on street tires and hit anything below a 12.7 on slicks. Got two days of racing coming up so the car should see a good amount of passes.
Will post some results tomorrow.
Old Apr 13, 2011 | 03:52 PM
  #80
are u running the 2.8 or r u going to run a smaller pulley?
Old Apr 13, 2011 | 04:50 PM
  #81
ULWizSS's Avatar
Running a 2.8.
Unfortunately not gonna run now either thur or friday. Went over a pot hole today and broke the stock H/E on the front drivers side. Gonna be a few more days until i can run it.
Old Apr 13, 2011 | 08:10 PM
  #82
well damn. sorry to here it.
Old Apr 13, 2011 | 09:54 PM
  #83
ULWizSS's Avatar
Major pot hole filled with water.
Old Apr 13, 2011 | 10:04 PM
  #84
D_Rob's Avatar
Ouch man. That just sucks. Note to self, steer clear of Jerseys potholes. I'm sure you'll get it back up in no time.
Old Apr 13, 2011 | 11:16 PM
  #85
ULWizSS's Avatar
Hmm its not the stock HE thats busted its the radiator which should be a easy fix and find. Located one 30 minutes away already. Got a buddy coming here in the morning to help me fetch and install the radiator. Then out to pick up the slicks and back home to shave whatever is needed to fit the rims on.
If all goes well i will still have results tomorrow.
Old Apr 14, 2011 | 11:50 AM
  #86
awshopskater14's Avatar
I've been checking this everyday. I have similar mods. I hope you break 12s. It will give me motovation to get mine to the track again.
Old Apr 14, 2011 | 04:09 PM
  #87
ULWizSS's Avatar
Well its definately the radiator and it was taken out this morning. Replacement will be here at 10am tomorrow morning. Buddy is coming to pick me up and we are going to install it in the afternoon.
Got the slick back today all ready to go as well. Got it grinded down to fit the wheel. Not to much shaving needed at all to make it fit. Did not really care what the wheels looked like as long as it was functional. Got a pair of Verde Protocols i believe they are called and are 6 pounds lighter than stock. If the stock weight is 24 that is.
Old Apr 15, 2011 | 09:18 AM
  #88
ULWizSS's Avatar
Well my buddy is on the way down and i should be getting a call any minute letting me know my radiator is in. Cost me a furtune having it overnighted but i dont really care about that. Should have it up and running again in a few hours.
Will also be running my buddies TC thats has a few bolt on and is BYT Tuned. Unfortunately he needs a slight driver mod since the best he drove it at was 14's.
Hoping the car will bang a mid 12 with the slicks on but will have to learn tires pressure and what to set the box at for optimal launching. Gonna start at 3-5k launched and see how it works out.
Old Apr 15, 2011 | 09:31 AM
  #89
crazywhiteboy89's Avatar
Ur not driven on them to the track are u??
Old Apr 15, 2011 | 10:33 AM
  #90
ULWizSS's Avatar
Adam you think i was born yesterday, lol Of course not .
Old Apr 15, 2011 | 10:52 AM
  #91
Lol I was just checking lars lol
Old Apr 16, 2011 | 12:23 AM
  #92
ULWizSS's Avatar
Results are in, lol
Old Apr 16, 2011 | 12:32 AM
  #93
ULWizSS's Avatar
Atco was packed last night. Test and Tune, 8.5 & 10.5 index running as well. Got to the track at 6:15 and finally made my first pass of the night at 8:30. It was an exciting one for sure.
YouTube - ULWizSS First Slicks Pass
Old Apr 16, 2011 | 12:34 AM
  #94
D_Rob's Avatar
You got your 1st view man
Old Apr 16, 2011 | 12:38 AM
  #95
ULWizSS's Avatar
Apparently never hit the play button on my iphone.
I expected to break the axels next so its no biggie at all to me. More pissed about the 200 bucks it cost me to get it towed back.
Not sure what to go with for axels definately cant have them breaking like butter on a little 3k launch. Need to talk to Nick and touch base with ZZP as well.
Dont trust the LNF axels holding the abuse so either stage 2,3. Not sure if Stage 1 will do. My car usually goes to the track 4 times a month with about 20-30 passes a month. I need something thats gonna take that abuse.
Old Apr 16, 2011 | 12:39 AM
  #96
D_Rob's Avatar
Wow man. What happened?
Old Apr 16, 2011 | 12:51 AM
  #97
ULWizSS's Avatar
Definately seems like a broken axel, Could not see it broken since it was dark. Trans gets in all gears including reverse so has to be the axel.
Old Apr 18, 2011 | 11:11 AM
  #98
ULWizSS's Avatar
Well here is the damage that occured.
Ordered ZZP Stage 3 Axles this morning and a new ic pump. 1245 shipped, OUCH
Car will hopefully be done by friday so i can hit the track up again.
Old Apr 18, 2011 | 12:10 PM
  #99
DarkChild's Avatar
You must save lots or have a killer job. Lol, I wish I could put money into my car like that. GL
Old Apr 18, 2011 | 12:26 PM
  #100
ULWizSS's Avatar
Definately dont save as you can see but do make really good money doing IT work in 5 states for wawa. I am also 32 years old and not one of these young bucks making 10 bucks an hour.
It sure helps if you go to the track as often as i do.
