12.9 to 13.2 possible with new upgrades?
Old Apr 23, 2011 | 10:34 AM
  #126
ULWizSS's Avatar
Originally Posted by LS6Rally
May sorry to hear about your unfortunate luck at the track. I know it sucks, but its nice to see someone like yourself who understands making power cost money adn **** is gonna break. i hate it when some of these guys make 400 WHP and **** breaks, then they whine about it like girls. ITS GONNA HAPPEN.
but im not sure you broke the trans, but i wasnt there. if you cant depress the clutch the trans is connected to the motor. if the car jerks forward when you try to start it that means its still engages. have you ttried putting the shifter in neutral and starting it? or throwing the front end of stands and seeing if it will start?
Yeah according to the shifter the car is in neutral when it jerks forward. Yeah it sucks i had cooling issue and could have most likely pulled a nice run with the 1.93 60ft.
Yeah after this the car has seen 11k ish in parts in roughly 6months time. It just dont love me right now but hopefully will soon. You should definately not beat on the car if you dont expect to break and should rather be driving it like an old lady.
Old Apr 23, 2011 | 12:26 PM
  #127
RooTBeeR's Avatar
wow, just read all the posts lol that took a while
Old Apr 24, 2011 | 10:38 AM
  #128
ULWizSS's Avatar
Appreciate you reading the thread, unfortunately the car has still not made a honest pass due to a few random breaks and issues going down the track.
Car is being taken apart on monday so i will hear what actually broke on it. Since the trans is being pulled off anyways i have decided to get the zzp stage 2 trans for the car even if my trans is still good. Need to see if i can ship it back to zzp for credit. Will also pick up another exedy or a zzp clutch just in case i need it.
Not going to make my appointment here in 6 days for my meth install with Nick so will have to wait a few thousand miles until i feel its broken in.
Will keep everyone posted on whats going on will try and post picks of what broke.
Old Apr 24, 2011 | 11:11 AM
  #129
mrbelvedere's Avatar
i would make sure u got the lsd installed in the zzp trans i dont think its a standard part in their transmissions
Old Apr 24, 2011 | 11:37 AM
  #130
gbkglenn's Avatar
hi my name is glenn i have a 2008 HHR with a 2.2 i add a SC a year ago now i had my head ported some ,put in vavles springs and stage 2 cams from zzp . have you build you motor ? i see you are useing a 2.9 pulley thats what have but my car have'nt been build try to see if i should keep used the 2.9 or go to a 3.0 or 3.1
Old Apr 24, 2011 | 11:45 AM
  #131
ULWizSS's Avatar
My motor and head are still stock and i am on a 2.8. Might drop to a 2.7 not sure what your goals are with the car.
Old Apr 24, 2011 | 02:33 PM
  #132
blackcobalt1986's Avatar
you know you have enough power when u keep breaking stuff. if you arent breaking anything you dont have enough power.
Old Apr 24, 2011 | 03:50 PM
  #133
most people break stuff because they cant drive their car
Old Apr 24, 2011 | 04:14 PM
  #134
WSFrazier's Avatar
+1
It's not power.
Old Apr 24, 2011 | 04:44 PM
  #135
every thing has a breaking point thats why i use drag radials they are more forgiving then slicks
Old Apr 24, 2011 | 04:49 PM
  #136
ULWizSS's Avatar
Completely dont agree here, its just the opposite.
Old Apr 24, 2011 | 05:08 PM
  #137
WSFrazier's Avatar
Yup.
Nothing wrong with a radial, but on a FWD, I would much rather have a bias ply tire.
Old Apr 24, 2011 | 05:53 PM
  #138
ok so nothing has a breaking point and radials arent more forgiving i bet if you had a radial on ur car your axel wouldent have broke
Old Apr 24, 2011 | 05:55 PM
  #139
WSFrazier's Avatar
The bias ply tire will absorb more of the shock than any steel radial will. Your axles will see more hurt from a steel radial. If you know what your doing, you can make either work.
There are plenty of people running oem axles with bias ply slicks running faster times than you.
Old Apr 24, 2011 | 05:58 PM
  #140
well to a point yes but when you dead hook u stress the whole drive line harder on a slick then a radial especialy if you cant drive
Old Apr 24, 2011 | 07:21 PM
  #141
ULWizSS's Avatar
Yeah i would say i made roughly 60 passes last season with the car on street tires. Was easing the car out of the hole and not really truely launching it like i was with slicks. Street tires i was leaving at 2k and the first pass on slicks where i broke i side stepped the clutch instead at 3k and snapped.
When i went back again last time i had some cooling issue/ The zzp stage 3 axles where on along with max boost set to 100. First two launches were at 3k and the last one at 4k. The two launched from 3k netted me almost two identicle 2.0 60ft each time and when i set the 2step to 4k i pulled the 1.93. I would have turned it up to 4.5 and would expect a 1.8 but with cooling issue there was no point. Slicks where not spinning and just dead hooking the car, almost missed the 1st to 2nd shift cause it came up so fast. The slicks and the wotbox would definately make you 60ft more consistant and is going to help me shave time once this thing actually runs right.
Might have a surprise under the hood besides the new trans and possible clutch. Numbers are 1.3 if it gives a clue.
Old Apr 24, 2011 | 07:32 PM
  #142
G11's Avatar
G11
1.3 or 2.3?
Old Apr 24, 2011 | 07:54 PM
  #143
ULWizSS's Avatar
Originally Posted by G11
1.3 or 2.3?
1.3 for sure
Old Apr 24, 2011 | 08:41 PM
  #144
tvs
Old Apr 24, 2011 | 09:12 PM
  #145
RooTBeeR's Avatar
1.32l
Old Apr 24, 2011 | 10:55 PM
  #146
G11's Avatar
G11
i was thinkin 2.3 stroker cuz of him sayin zzp lol! but i guess it is considered a 2.4 now.... and im wantin to do a tvs here too but not sure when i should lol!
Old Apr 24, 2011 | 11:12 PM
  #147
DarkChild's Avatar
Do a TVS... Not trying to thread jack but I am getting a steal on one with a set of injectors so I am picking one up as well.
Old Apr 24, 2011 | 11:14 PM
  #148
G11's Avatar
G11
well im doin coilovers and cf hood right now just tryin to decide if i should pay the car off first before i do more...but i get the mod bug too much! if someone offered me a tvs for 1400 i would probably do it! hint hint lol!
Old Apr 25, 2011 | 09:39 AM
  #149
WSFrazier's Avatar
Do you have E85 available in your area? It will really wake up the TVS. Not sure if I would get one without it.
Old Apr 25, 2011 | 09:41 AM
  #150
ULWizSS's Avatar
Not really available we might have 4 gas stations max between nj and pa.
