1st to 2nd Gear Sux @ WOT ?
Old Jul 27, 2010 | 07:21 AM
SunburstSS's Avatar
Exclamation 1st to 2nd Gear Sux @ WOT ?
The search isn't working for me today...
The problem i'm having is the following...
If I go to shift from 1st to 2nd gear @ WOT the car wont shift properly and get stuck...
The shifter will be in 2nd gear but the rpms are stuck on 6ks or whatever the rpm's are, then inorder to get it to shift I have to let go of the gas for like 2 or 3 seconds then it'll go to second and the rpms will drop down...
I've swapped clutches not too long ago, it happened with a stock clutch and my current stage 2 clutch so i know its not the clutch, transmission was replaced about 15 k's ago...
Would it be a matter of adjusting cables ?
Would it be the linkage pin ?
Syncros ? Hope Not
Change Transmission Fluid ?
Any ideas are much appreciated...
Old Jul 27, 2010 | 08:20 AM
Erick161's Avatar
Are you sure the clutch isnt slipping? It doesnt matter if the clutch is new, it might not have been broken in correctly.
...thats what it sounds like...
Old Jul 27, 2010 | 08:30 AM
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
rotato potato stage2 mount! /thread!!
samething happen to my car.....
Old Jul 27, 2010 | 08:33 AM
DVSk8er's Avatar
yea thats the clutch slipping and if it keeps happening that clutch disc is going to be glazed
Old Jul 27, 2010 | 09:20 AM
SunburstSS's Avatar
I'm a 100 % sure its not the clutch or flywheel the clutch doesnt slip at all !!!! i don't know if this helps sometimes i when i want to shift to another gear 3rd to 4th it wont let me do it even if i try to force it " no thats what she said jokes please " I would have to let it roll for a second or two then clutch again and force it in and goes through fine....
Old Jul 27, 2010 | 09:46 AM
phatnackySS's Avatar
Sooooooo.... so let me get this straight...
you push in the clutch...put the car in 2nd ...let out the clutch when this happens
There are only 2 things that can be happening , wheel spin or clutch slip ...that's it.
your 3rd and 4th gear problems are due to toasted syncros
<mini rant> i miss the days when car people took the time to learn how cars worked </mini rant>
Old Jul 27, 2010 | 09:50 AM
ecot3c inside's Avatar
this never has happened to me........
Old Jul 27, 2010 | 10:07 AM
SunburstSS's Avatar
car is going to my cuzzo's shop today...so we'll see what's going...lucky him he knows how a car works.....
Old Jul 27, 2010 | 10:34 AM
Im still tring to fully understand what your saying.
Are you saying you put the car 2nd gear and let the clutch out while still on the gas? if so that's a slipping clutch or just the wheels spinning.
A manual tranny is all mechanical , if the shifter is in 2nd then the trans is in 2nd,if you had broken shift linkage the shifter would just be loose inside the car as a result of not being attached to anything. or if the linkage was loose the shifter would have a lot of extra play but that wouldn't cause the problem you are describing.
the only part that would let the engine freewheel like that is the clutch. another thing would be a slave cylinder that isn't disengaging all the way thus causing the clutch to slip, but you would get a hard clutch peddle as a result of something like that.
the only other thing i could think of would be broken shift fork inside the trany ,then it wouldnt engage a gear no matter what you did,it would ether be stuck in one gear or just not go into gear, and the shifter would feel detached .plus the fact that as the rpm drop the trans "engages" tells me its not a shift fork.
Sounds like the clutch is toast.
now if you push and hold in the clutch and the shifter wont slide into gear until the rpms drop that's a syncro problem. from what you describe it sounds like you have both problems. From what i gather im gonna beat you beat on this car pretty good eh?
The only reason i made my comment at the bottom of my last post is becasue people are telling you whats wrong but you aren't accepting the answer.
Old Jul 27, 2010 | 10:58 AM
SunburstSS's Avatar
Thanks a lot for your answer man, i really appreciate the explanation, it makes sense now, this is not my 1st car 2nd or 3rd, this is my 5th manual transmission car, i know how to drive and i know cars too, but not everybody knows every little detail, thats why I ask questions, now im in 1st gear lets say going 10mph i step on it all the way, i get to 6ks, i take my foot off the gas then engage the clutch, shift to 2nd gear, then step on the gas again. however it seems like its stuck in 1st gear, i would have to take my foot off the gas and then it will shift again.
I never ever launched the car coz i don't stiff mounts yet, but i do step on it in 1st gear like once or twice a month, i don't get any wheel hop but thats a diff. subject....
I baby my car, i never took it to the track or anything like that, its my DD so i take good care of it... so i guess we'll see whats going on with it today... but yeah thanks again for the response man...
Old Jul 27, 2010 | 11:11 AM
clutch slip, if it feels like its in 1st when u are in 2nd, thats the clutch not catching
learn to control the boost and it wont slip.
sounds like u hit 6k in 1st and when u hit it in 2nd it slips resulting in the car trying to go but it wont and it u dont get off u will toast the clutch
Old Jul 27, 2010 | 11:15 AM
few more question. DO you have any issues when driving normal ?
when you say you take your foot off the gas and it will shift again, are you saying it feels like it shifts ? or are you taking it out of 2nd and putting back into 2nd by hand?
If it feels like it shifts then most likely clutch.
also is there any smell when this happens.
anything can cause a slipping clutch, could be a bad main seal on the engine, or tranny oil leaking on the clutch from a cracked trans or leaking tob/slave/seal
Old Jul 27, 2010 | 11:28 AM
Stone629's Avatar
Like everyone else is saying, its slipping.
Old Jul 27, 2010 | 11:48 AM
daedlus's Avatar
I am not so sure its slipping. I am having the same issue. For me 1-2 was bad right after a clutch swap. 2-3, 3-4, 4-5 work, but it seems stiff. I will be adjusting my shifter cables before the weekend.
I have a brand new GMPP clutch, flywheel, TOB, and all new fluid. Clutch was broken in for 500 KM, many heat cycles over almost a week.
I will update when I have done the adjustment.
Old Jul 27, 2010 | 12:28 PM
SunburstSS's Avatar
sweet deal lemme know man
Nope i never have a problem during daily driving at all, sometimes it will go into second on its own when i take my foot off the gas and sometimes wen it doesnt i put it in neutral then put it in second again, and no there's no smell at all every single time. That's why im dazzled...
The car is at the shop now he's taking it for a test drive soo we'll see what happens
Old Jul 27, 2010 | 01:31 PM
Stone629's Avatar
Curious to see what they find.......
Old Jul 27, 2010 | 01:40 PM
BlackJackSS's Avatar
does the peddle get spongy? or feels like you have no peddle. and you have to pump it back up?
Old Jul 27, 2010 | 03:41 PM
SunburstSS's Avatar
Talking
naaah actually it feels normal nothing really different with the clutch pedal...
Ladies And Gents The Problem Has Been Found And Resolved....My Linkage Roll Pin Was Shattered , We Got That Replaced And The Car Runs Sweeter Than Before, The Shift Feels So Much Better Than Before, We Also Readjusted The Shifter Cables Just To Make Sure Everything Is To Specs , I Can Shift From 1st To Second Normally Without Any Problems Whatsoever, All Gears Engage Properly...Clutch Seems Fine With No Slippage And There Was No Need To Open The Transmission Up.
Thanks for everybody's opinions and trying to help !!!!
I'm a happy camper now
Old Jul 27, 2010 | 04:32 PM
Stone629's Avatar
Nice!! Glad you got her up and running like she should be!
Old Jul 27, 2010 | 07:53 PM
SunburstSS's Avatar
tnx dude i appreciate that !
Old Jul 28, 2010 | 11:47 AM
YEAY!!!!!!!
i love a good ending
Old Jul 28, 2010 | 03:30 PM
SunburstSS's Avatar
YEAY!!!!!!!
i know right i love it now its shifting great !
Old Jul 28, 2010 | 09:58 PM
Omega1x's Avatar
Glad you got it figured out. Thinking my roll pins and synchro's might be going...
Old Jul 30, 2010 | 02:26 PM
daedlus's Avatar
I adjusted my shifter cables and everything is as good as it was stock. Glad you got yours fixed as well!
Old Jul 31, 2010 | 12:29 AM
SunburstSS's Avatar
good to know that as well bro...thanks a lot !!!!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
riceburner
Oct 2, 2015 05:47 PM
