2.0 conversion too .2 or .4
Old Feb 28, 2015 | 02:45 PM
charizard's Avatar
can i put a 2.2 or 2.4 in my ss bay?
Old Feb 28, 2015 | 02:49 PM
no_ss's Avatar
should be able too. May need few different parts but idk what parts but I don't see a reason for GM to change the position of where the engine would mount up just for different engines. Probably just different mounts or something. Gotta look into though. I'm sure if you can swap a 2.0 into a 2.2 engine bay you can do vice versa
Old Feb 28, 2015 | 04:03 PM
T-fog's Avatar
Yep its possible, Technically you can do what ever you want, If you got the money lol
Old Feb 28, 2015 | 11:17 PM
andrewcarr1993's Avatar
It's been done, but why? Takes a lot of work and you'd need to built the engine as well as keep the LSJ head regardless.
Old Feb 28, 2015 | 11:27 PM
mrbelvedere's Avatar
and rewire the entire car
Old Mar 1, 2015 | 12:47 AM
How did TJolly (close enough) get his 2.4 LSJ running then?
Old Mar 1, 2015 | 12:49 AM
slapbetcommissioner's Avatar
As a strait swap it's allot of work but you can build an lsj in excess of 2.3l and it's basically a motor swap then.. Not cheap by any means.
Old Mar 1, 2015 | 12:53 AM
https://www.cobaltss.net/forums/2-0l...er-lsj-305263/
Not for the faint of heart and would require a built engine.
Old Mar 1, 2015 | 09:08 AM
a lsj is a 2 litre engine swapping a head on a 2.4 dose not make it an lsj engine it still makes it a 2.4 to run a 2.4 you need to reclock the relucter and run the lsj head and it does not require a built engine to do it and this has been done a few times if you want to run a 2.4 and keep the vvt then you will need to swap an entire harness in from a donar car
HEATON
Oct 16, 2015 07:21 PM
Sep 28, 2015 12:51 PM
dennis69
Sep 22, 2015 08:56 AM
n20saturn
Sep 21, 2015 01:50 AM
