2.0 lsj conversion questions
Old Nov 10, 2008 | 03:12 PM
ky boy's Avatar
I am going to install a 2.0 s/c in my sand rail. And I need some help. Does anybody know what all I will need from a donor car. I know I will need engine harness and ecm. But will i need the bcm to. I would greatly appreciate any info. Oh yeah does anyone have the wiring diagram for this motor. Thanks ky boy
Old Nov 10, 2008 | 03:32 PM
brandon2.2's Avatar
are you taking the whole "transaxle" as well?
pretty sure the computer (ecm, pcm, ecu or whatever) will work.
engine, tranny, differential and axles...should be good I think
hopefully some guys more experienced with swaps will chime in
Old Nov 10, 2008 | 05:09 PM
Speedytec's Avatar
LSJ will work with only the (engine) ECU, but you need (someone with HP-tuners) to switch of the VATS immobilizer. Otherwise you need the BCM, key and lock etc. with it to be able to run it...
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
Sep 28, 2015 12:51 PM
