2.0 lsj stuff in 2.2
Old Feb 10, 2009 | 11:07 PM
That Cobalt LT Guy's Avatar
I need to know if the 2.0 lsj piston and rod combo will work in the 2.2 l61.
No flaming.
Old Feb 10, 2009 | 11:14 PM
HunterKiller89's Avatar
short answer....no
you would need the LSJ crankshaft too, and they have different reluctor wheels (i think thats what theyre called?) than the L61, so it wont work electronically. You can use the LSJ pistons if you have a custom set of rods made, or the LSJ rods if you have a custom set of pistons made. Regardless, you'll be buying some custom aftermarket parts, so its cheaper to just order a set of L61 forged parts
Old Feb 10, 2009 | 11:17 PM
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/cobalt-parts-interchangeability-58013/
In this tread is says you can. and in the build book it say the rods definatly will work. The lobes are the same size on both cranks.
Old Feb 10, 2009 | 11:29 PM
ls1fbody's Avatar
Haz l33t wheelz.
If it says that in the build book, why did you ask?
GM Engineers > Forum Trolls
Old Feb 10, 2009 | 11:40 PM
because it doesnt say any thing about the lsj pistons and rods used togather in it.
Old Feb 10, 2009 | 11:55 PM
tdipowered's Avatar
lol luckily im 6'3" IM NO TROLL
Old Feb 11, 2009 | 12:25 AM
ls1fbody's Avatar
Haz l33t wheelz.
What size bore is the L61?
Old Feb 11, 2009 | 12:27 AM
umrdyldo's Avatar
I remember someone saying the pins in the pistons are different or something along those lines. Why not get all aftermarker rods and pistons?
Old Feb 11, 2009 | 12:31 AM
ls1fbody's Avatar
Haz l33t wheelz.
Originally Posted by HunterKiller89
short answer....no
if they work individually, why won't they work together? just curious. I don't have experience or knowledge with the L61 stuff like you do.
Ok, that would make sense why the 2.2 parts aren't interchangeable with the 2.0 ones, but what stops the whole rod/pin/piston assembly from working?
Old Feb 11, 2009 | 12:45 AM
Tinkles's Avatar
LSJ 86mmx86mm
L61 86mmx94.6mm
The crankshaft throw determines the stroke of the engine, not the lenght of the rods or wrist pin location. If you want to use LSJ internails then you have to use the crank, rods, and pistons. Assuming that your goal is to destroke the L61.
Old Feb 11, 2009 | 12:49 AM
I cant remember off the top of my head, but I remember (i think) Halfcent explained it to me and it made perfect sense (it might have been NJHK/adam). Ima try n remember how he explained it to me
Looks like Maven said the same thing. Maybe the rods just dont work at all..?
EDIt: nvm...it has to do with each piston using a different pin height and having a different rod length
https://www.cobaltss.net/forums/show...t=58013&page=4
Post #136
Originally Posted by Maven
In order to use pistons for the LSJ/2.0 in an L61/2.2 you need special "adapter" rods.
GM offers them.
If you put 2.0 pistons in a 2.2 without these rods the engine wont turn over.
and post #169
You cant swap pistons and rods between different size engines. The reason is because all 3 displacements(2.0, 2.2, and 2.4) each use a different length rod, and piston with a different pin height, also the 2.4 has a large bore than the 2.0/2.2 so the pistons wont even fit in the cylinder.
IE: you cant put LSJ pistons and rods in an L61 You cant put LE5 pistons and rods in an LNF, you cant put L61 rods/piston in an LSJ
In order to mix/match pistons and rods amongst the engine you need to use one stock part and one custom part. for eample if you wanna put LSJ rods in an L61( a reasonable upgrade) youll need to get custom pistons made.
Old Feb 11, 2009 | 01:09 AM
ls1fbody's Avatar
Haz l33t wheelz.
super, there are all of the answers in one spot...
Old Feb 11, 2009 | 01:16 PM
Maven's Avatar
werd.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
Sep 28, 2015 12:51 PM
