2.0 turbo baby!!
Old Jun 14, 2007 | 04:15 PM
  #76
MISSMATCHEDFACES's Avatar
like i posted before, they redisgned the kit, this is their new kit. it is no longer the big airbox that sits on the intake manifold. it is a streamline flat piece that sits over where the s/c used to be.
Old Jun 14, 2007 | 04:24 PM
  #77
PuSha050's Avatar
thats the way it should be. that big box was a waste
sweet deal .. good luck wit that
(and a little hint to everyone who types subscribed--- if you just hit thread tools at the top of the page, you can click subscribe to the tread so its just like u posted in it.. and it saves useless posts so people like me dont have to look thruu 3 pages of subscribed messages) lol just thought id give a little advice if some1 didnt kno about it
Old Jun 14, 2007 | 05:07 PM
  #78
p7x's Avatar
p7x
nice!!! that looks way better than the original.
What did they do with the throttle body setup?
Old Jun 14, 2007 | 05:12 PM
  #79
the other end of that hooksup to the throttle body
Old Jun 14, 2007 | 05:16 PM
  #80
p7x's Avatar
p7x
cooooo, cant wait too this puppy in action after its all tuned and dialed in. Godd luck man and keep us posted on everything.
Old Jun 14, 2007 | 05:31 PM
  #81
07 SS/SC's Avatar
Damn that is going to be awesome man! I cant wait to see the finished install and some vids of it!!! Good luck with installing everything this weekend, I hope it goes smooth.
Mike
Old Jun 14, 2007 | 06:03 PM
  #82
Apex's Avatar
all these turbo balts are making my nipples hard haha
what is the expected hp output of these?
Old Jun 14, 2007 | 06:04 PM
  #83
blu3_v1p3r's Avatar
Originally Posted by arng22
saddle brook Nj
how far is that from hopatcong nj?
i want to see it :-)
I used to live in roxbury... more specifically... landing...
Old Jun 14, 2007 | 06:06 PM
  #84
yellowcobaltss05's Avatar
holy shat im so excited i wanna see vids!o and dyno graphs!!!
Old Jun 14, 2007 | 06:18 PM
  #85
blu3_v1p3r's Avatar
Does anyone know what type of power the 2.0 would have with out the s/c? wouldn't it be less then the 2.2... if so wouldn't theory say that a turbo on a 2.0 would make less power then a turbo on a 2.2
Old Jun 14, 2007 | 06:20 PM
  #86
not true...@18psi i think the turbo will put the car at 325whp and i even heard upping the boost to 22psi you will be at 400whp!
Old Jun 14, 2007 | 06:38 PM
  #87
blu3_v1p3r's Avatar
I find it hard to belive that just switching to a turbo is going to give that much power... If you think about it, the 2.0 with out a supercharger, would put out, i'll just say 140hp, so your saying a turbo will give the car 185 hp...
Ok so a 2.2 that is 147 hp if you add the same turbo should have the same results...
Now a 2.0 would have less power then a 2.2 right? So without the supercharger it would produce about 135-140 hp
If there is something i'm not under standign please let me know
Old Jun 14, 2007 | 06:44 PM
  #88
IonFeright's Avatar
the 2.0 has lower compression. lower compression means good for boost
Old Jun 14, 2007 | 06:57 PM
  #89
blu3_v1p3r's Avatar
You can lower the compression on a 2.2 also, so basically when tuning is available for 2.2s it will run in the 300 hp range... am I correct or no? and is there a way for twin turbo set up?
Old Jun 14, 2007 | 07:06 PM
  #90
i dont feel like explaining it honestly lol turbos are just much more efficient in making power and some other turbos on half the boost that the TAG's turbo puts out will put out the same power bc all turbos are different.
Old Jun 14, 2007 | 07:10 PM
  #91
an0malous's Avatar
to truely do the comparison your talking about, you have to realise the LSJ is built to handle boost....
when you compare the 2 with the supercharged taken off.....
in all fairness you would have to give the LSJ some high compression pistons....
because the 2.2 makes power with compression
the LSJ makes power with boost.
so if you put those pistons in your LSJ, its gonna be more than 140hp.....
all in all its a very coonfusing way to look at things.
the 2 motors are built with different goals in mind so its hard to compare them fairly.
Old Jun 14, 2007 | 07:17 PM
  #92
blu3_v1p3r's Avatar
I'm kinda new to the whole tuning thing, so i'm trying to learn, but it seems to me that a 2.0 would not produce as much power as a 2.2 and the 2.2 does not produce as much power as the 2.4... even if the 2.0 had high compression pistons...
my guess would be
2.0 around 130 to 135
2.2 is 145
2.4 is1 71
Old Jun 14, 2007 | 07:22 PM
  #93
Witt's Avatar
my guess would be
2.2 is 145
2.4 is1 71
As others said, its the original intent in mind for the engineers designing them. A lot of factors play into how much power each ecotec makes.....the timings and lift of the cams, the compression of the pistons, the desired engine redline (due to stroke and rotating mass) all factor into play. Each engine is very unique in how it gets air in and out of the chamber and displacement is only one of those factors.
Old Jun 14, 2007 | 07:41 PM
  #94
p7x's Avatar
p7x
ya, Mase dynoed my car with bypass and the LSJ without S/C made 133whp. Redbasebalt dynoed his car at the TAG BBQ and it made around 127whp...... There's ur answer. Granted both have mods, so stock for stock Im not sure, but I like the fact my N/A 2.0L made more whp.
Old Jun 14, 2007 | 08:32 PM
  #95
blu3_v1p3r's Avatar
i figured it wou;ld be close to that, and does 325 hp sound like what his results will be form a turbo?
Old Jun 14, 2007 | 08:38 PM
  #96
p7x's Avatar
p7x
wit this setup 300whp+ easy, depending on tuning and PSI, Jon the guy with the concept kit is supposedly making 406whp. Thats why we're all wondering how this guys kit will run and hp #'s
Old Jun 14, 2007 | 09:01 PM
  #97
blu3_v1p3r's Avatar
I know this is a 2.0 thread... but is it possible for the same results from a 2.2? Ijust didn't think it was a reasonable gain to be in the 300s+ just by adding a turbo... but i guess with that much boost its possible, but how long will and engine handle 18-20 psi before it blows up like a time bomb?
Old Jun 14, 2007 | 09:08 PM
  #98
p7x's Avatar
p7x
stock N/A engines should never really see more than 6-8 psi so if ur looking for big power u'll have to come to he realization of internals, BUT remember almost every 1000hp+ GM cobalt race car is based off the 2.2 engine. so the potential is there, 1000 hp is obvisously an extreme example.
Old Jun 14, 2007 | 09:18 PM
  #99
blu3_v1p3r's Avatar
ok well i've kinda thread jacked this thread... my apologies... P7x thanks for the info...
Old Jun 14, 2007 | 11:59 PM
  #100
cobaltboy69's Avatar
ya enough of that....turbo=wet dreams....all i can say on that...but is this the set up from TAG?
