2.2 lsj turbo build
That's already done. I don't need it. But it's good to have. My concern now is the ports between the intake ports. Can any one tell me what they are? My mani doesn't cover one of them.
did a lil work today.
welded alt for turbo swap.
clocked turbo and made up stainless an fittings line for the oil return from turbo.
installed alternator and routed the 4 rib 41.5 in belt.
didnt think that the sam sensor should be able to spread apart like this.
so i ordered it a few days ago and installed today.
valve cover to oil pan. shed done and ready for starter and flywheel then back on the trans.
first start up this weekend.
ok guys. had a very good weekend. got some good work done. here go the pics.....
Intake and boost controller and bov and waste gate are now final install. boost controller is over the fuse box.
and no. the charge pipes and intake do not touch. theres about .5 of an inch in between and they dont rattle or hit with engine running.
figured out were im mounting the ctach can and will plumb that all in with the new valve cover tomorrow.
things left to finish.
1. Bleed clutch
2. Finish evap connection to my brfps.
3. Connect vac for the meth kit.
4. tap intake for vac sourve for pcv system.
5. route pcv/catch can set up. (hopefully done tomorrow)
6. tune
Only thing I have is some pulleys for the TVs. I sold most of the supercharger parts for the turbo set up. So the end fame of this project is 6262 pte with meth and nitrous.
^^^^ whats up guys. They are correct. Bates sleeves bored to 90mm 3.543". its a l61 block with lsj guts basically. I used boring to get more displacement. Custom 1 off je pistons fill the holes. well they were when i started this build.
well here is the finished pcv system. only thing left is a check valve fitting im waiting to come from summit...
also powell shipped out one of these to me this week.
powder coated fuel rail to mach my valve cover and intake manifold. ( soon to match my charge pipping also....)
