2.5 inch WITH STAGE 4 FROM INTENSE
Old May 22, 2007 | 12:26 AM
ssg85ss's Avatar
Is It Safe To Run A 2.5 Inch With Intenses Stage 4. They Say You Can Run It But Werent That Assuring.
Old May 22, 2007 | 12:40 AM
Mikey851's Avatar
You can run what you want, but you shouldn't run a 2.5" pulley in the first place. It's doesn't present many positive effects but it will negatively affect many components of your engine including the supercharger.
Old May 22, 2007 | 03:13 PM
ebristol's Avatar
Size does matter but dont get caught up in all the 2.6, 2.5, 2.4 crap. I know it sounds cool to say "I have a 2.5" pulley" but you will look stupid when you blow your engine. Just make sure to run a safe size with your setup. Without custom tuning (and someone who knows what they are doing) I wouldn't recommend anything lower then a 2.7" pulley with 60# injectors.
There was a huge shift about a year ago where a lot of people went to 60# injectors and a 2.5/2.6 pulley just because it was finally available through aftermarket vendors. Now I am starting to see people smarten up a little and go with safer setups. And safer doesn’t always mean slower.
Old May 22, 2007 | 03:17 PM
TCarter's Avatar
actualy, anything under 2.55" will overspin your blower....so you will get the same hp running a 2.55" pulley vs a 2.3"
but the 2.3" will burn up your bearings.
Old May 22, 2007 | 03:18 PM
3fo893013L's Avatar
I just made the leap to a 2.7 and 60lb injectors. Trust me, for now it's enough.
Old May 22, 2007 | 03:21 PM
blown06's Avatar
make sure you have ALL of the cooling mods and money set aside for the pistons when #4 decides to go
Old May 22, 2007 | 08:45 PM
mezzanno's Avatar
Im running a 2.6 with 60's and the car is a beast. I was customed tuned by bcp though. Like said above get cooling mods. I have meth injection and a heat exchanger. Going to add a dual pass later on this summer.
Old May 22, 2007 | 08:51 PM
Bika's Avatar
Fail Less.
lmao... a 2.5" pulley is NEVER safe. and yes, less than a 2.6" will overspin the blower, ruining the bearings and creating excessive heat. i believe the maximum rpm of the m62 blower is 17,000rpm. unless you replace the bearings with the 20,000rpm bearings
hacadacalopolis
Oct 28, 2015 06:09 PM
HEATON
Oct 16, 2015 07:21 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
