2.6 pulley or 2.7 pulley
Old Oct 18, 2007 | 05:35 PM
Fast Freddy's Avatar
Question 2.6 pulley or 2.7 pulley
I have the stage 4 from intense racing. I was thinking about putting on a 2.6 pulley in stead of the 2.7. Any suggestions or comments? Thanks.
Old Oct 18, 2007 | 05:36 PM
Beck's Avatar
make sure you have the cooling mods/injectors and a custom tune to support it
Old Oct 18, 2007 | 05:41 PM
Area47's Avatar
Rent me! per hour
2.7.
AlphaJaguar5's Avatar
Don't go below a 2.7
Old Oct 18, 2007 | 05:42 PM
braddddddd991's Avatar
2.7.
Old Oct 18, 2007 | 05:44 PM
SSMOKEM's Avatar
why? I have a 2.6 and I like it.
Old Oct 18, 2007 | 05:47 PM
Area47's Avatar
Rent me! per hour
you can run more timing with a 2.7 than you can a 2.6
Old Oct 18, 2007 | 05:56 PM
chevysssc's Avatar
if your not sure im sure someone makes a 2.65
Old Oct 18, 2007 | 05:59 PM
ColeJJones's Avatar
Bannned
hahaha, 2.7. run it safe on this one
Old Oct 18, 2007 | 06:25 PM
nherbst454's Avatar
Yup, I'm sure "someone" can make a 2.65 to fit the Intense hub
Old Oct 18, 2007 | 06:38 PM
NJHK's Avatar
neither
Old Oct 18, 2007 | 07:11 PM
Blown 4-banger's Avatar
Go with a 2.6, make sure you have tons of cooling mods. On short bursts you'll be fine. If you plan on doing mulitple 150+ mph runs, don't even think about it.
Old Oct 18, 2007 | 09:57 PM
Any problems?? I have a 2.8 and it pulls very good with my old stage 3 pcm and 42.5 lb injectors. Now I have 60lb injectors stage 4 pcm, CAI, downpipe and exhaust. I want it to scream. Im a technician so if I blow it Ill just fix it. I was just wondering what most people are running and which they all perfer. Pro's and con's Thanks!!
Old Oct 18, 2007 | 10:01 PM
Doc's Avatar
Doc
screw it, go with a 2.5 then ...just make sure you have a way to cool the IAT2.
Old Oct 18, 2007 | 10:02 PM
an0malous's Avatar
Originally Posted by NJHK
neither
agreed.
2.8 ftw
Old Oct 18, 2007 | 10:04 PM
Doc's Avatar
Doc
let him build it after it blows....come on...encourage him
Old Oct 19, 2007 | 08:24 AM
LOL, I don't want to rebuild it unless I have too. I drive "NORMAL" 95% of the time ( between 65 and 80 on the highway and the speed limit on the side roads. The other 5% is saved for the A holes that think they are fast with their v8's. (100 to 150 on a clear Highway and up too 65 on the side roads)
Old Oct 19, 2007 | 08:26 AM
distillion's Avatar
2.7.
Old Oct 19, 2007 | 05:29 PM
BOOOOO!!! 2.5" sucks! The blower draws so much power after 6200 rpm the car starts losing power
Oct 20, 2015 09:56 PM
Builttss
Oct 4, 2015 10:21 AM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
