2.6" pulley on a bench grinded snout XD
Old Nov 10, 2010 | 10:44 PM
ecot3c inside's Avatar
I firstly assumed the 2.6" smootheflow 5 bolt would fit without snout machining, but I was wrong..... ended up taking off my supercharger and bench grinding the snout so it would fit. Love the extra whine and extra tq. I assumed the pulley would fit without machining because that IS what smootheflow said on here somewhere, I just need to find it.
anyone have some ideas for extra cheap hp?
my mods:
2.6", cobra h/e, e85, #80 injectors, header, dp, 3" exhaust, zzp 3" intake w/ k&n
what I want:
valve springs, sts, p&p head. better clutch
waiting to go on:
stage 1 axles.
yes, yes turbo swap is always going to be a suggestion
Old Nov 10, 2010 | 11:43 PM
Bluelightning's Avatar
Got Bewst?
Single pass. Or atleast a dual pass
Old Nov 10, 2010 | 11:46 PM
Bl4des's Avatar
single pass and better heat exchanger
Old Nov 11, 2010 | 01:43 AM
InfraRedline's Avatar
I ran basically that same setup at the track except on a 2.7 on the same h/e and no dual pass and trapped 109.7mph...
Although I would add a single or dual pass. I am doing that this winter for a little extra cooling, but it really shows that minimal cooling mods produce plenty of power when you are on E
Old Nov 11, 2010 | 02:01 AM
Got Bewst?
E is a beautiful thing. Damn Canada...
Old Nov 11, 2010 | 02:08 AM
ssblackstealth's Avatar
corn gas ftw....
meth kit.....
Old Nov 11, 2010 | 02:15 AM
Got Bewst?
Originally Posted by ssblackstealth
meth kit.....
Now thats something that has yet to be tried with E...
Old Nov 11, 2010 | 09:03 AM
383_Stroker's Avatar
i'm doing it right now.. .. i know there's an LNF doing it too
ninja edit: I only put e85 in to play with it, i've not seriously tuned for it yet.. and thats why my meth kit is still on
Old Nov 11, 2010 | 09:12 AM
JapEatr's Avatar
South Central *********
e85 is my favorite....
Old Nov 11, 2010 | 11:39 AM
meth kit eh? hmm maybe I will put it on my christmas list! I just don't want to keep buying gallons and gallons.
Old Nov 11, 2010 | 11:41 AM
really?, but with a dual pass do you need option b?
Old Nov 11, 2010 | 12:03 PM
Got Bewst?
An option b just makes bleeding the system a breeze
Old Nov 11, 2010 | 01:13 PM
If you run a meth kit with E85 you will only use distilled water through a small 1gph or so nozzle for cooling purposes only since you will not need any additional octane since you can run all the timing you want on E. I ran my meth kit with E for a while but decided it wasnt necessary.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
