2.6 pulley problem?
Old Jul 19, 2007 | 01:23 PM
eastcoastz's Avatar
2.6 pulley problem?
I've been running a custom tune with 2.6 pulley and 60lbs injectors and meth since january and the other day the car stopped making boost so I pulley over popped the hood to find my belt shredded and my 2.6 pulley in pieces! Funny thing is there was no abnormal noise that you would think you would get from this kind of failure. All four pulley bolts were tight so I instantlly thought great something locked up! Everything including the supercharger spun freely?! I took the blower apart to see if I could find evidence that the rotors hit the case, but I coundn't find anything? I've been running my 2.8 pulley with the stock belt since then and don't seem to have a problem. Has anyone had something like this happen to them?? If so did you find the problem? Thanks guys
Old Jul 19, 2007 | 02:25 PM
Jmc007's Avatar
Are you sure you didn't find a crow somehere jammed around the alternator LOL ..
Old Jul 19, 2007 | 02:38 PM
eastcoastz's Avatar
I wish! Then I would know what went wrong.
Old Jul 19, 2007 | 02:47 PM
MadboostSS's Avatar
do you have an Adjustable Tensioner? because anything smaller than a 2.7 you need one!
Old Jul 19, 2007 | 03:06 PM
eastcoastz's Avatar
MadboostSS, I have a Stage 2 belt and the Intense 76mm tensioner pulley.
Old Jul 19, 2007 | 09:41 PM
eastcoastz's Avatar
Today I drove her around for a while and popped the hood to check it out. Well the blower was warm and the nose drive and pulley were red hot! Isn't the nose supposed to be the same temp?
Old Jul 19, 2007 | 09:45 PM
Doc's Avatar
Doc
Originally Posted by nherbst454
Interesting, I know a guy that makes pulleys if you need a replacement
I heard the same thing....I think his name was Nate..?
Anyone know where he can be located
Old Jul 19, 2007 | 09:47 PM
yellowcobaltss05's Avatar
damn man that leaves me clueless **** i hope everything works out for you
Old Jul 19, 2007 | 10:12 PM
eastcoastz's Avatar
Yea Ive never heard of a nose going bad.
Old Jul 19, 2007 | 10:56 PM
MadboostSS's Avatar
ok so what are you trying to say??? i think you need to read it again
P.S Has got acquainted with the girl, http://cyberblady.com, how it to you? Only it is fair!
Old Jul 19, 2007 | 10:58 PM
SilverBalt13's Avatar
Maybe the bearings in the nose are going bad.... Take the blower off and check the bearings. CHange the supercharger oil while your in there.
Old Jul 20, 2007 | 11:12 AM
Apparently according to GM we never have to change our supercharger oil because it is lifetime oil is that BS true?
Old Jul 20, 2007 | 09:02 PM
JCobalt's Avatar
a peice of my 2.7 broke off. when i took it off there were scratches on the snout were it was rubbing. check the snout for signs of the pulley rubbing.(mine was rubbing on the bottom)
Old Jul 21, 2007 | 01:46 AM
U know that same thing happened to me w/ a 2.6 pulley
Oct 20, 2015 09:56 PM
Builttss
Oct 4, 2015 10:21 AM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
