2.7 and 42s
Old Oct 23, 2007 | 07:37 PM
hungryhip-ccp's Avatar
2.7 and 42s
just wondering how many people are running 2.7 pullies with 42lb injectors? I spoke with zzp yesterday and sent them a copy of my dyno run with a/f ratio and they said i could even run one more size smaller im running there custom tune with 2.8 right now... what do you guys think about this?? the idc is at 80-90% at wot at 7300rpm my elevation is nearly 3000ft and im only getting 15-16lbs boost with 2.8
Old Oct 23, 2007 | 07:38 PM
XM15's Avatar
I would upgrade to 60's if I were you and going with a 2.7
Old Oct 23, 2007 | 07:40 PM
tlax23's Avatar
Way to close for comfort.
Personally I wouldn't run anything less than a 2.8 on 42lbers
Old Oct 23, 2007 | 07:43 PM
Shortbus's Avatar
I ran 42's and a 2.7 for a while and the car did not like it at all, the idc were wild, and the a/f would go nuts in the upper rpm levels.
Old Oct 23, 2007 | 07:44 PM
an0malous's Avatar
damn there are countless arguments on the forums of how unsafe a 2.8 is with 42s, and your asking if a 2.7 is ok?
yeesh.
Old Oct 23, 2007 | 07:45 PM
distillion's Avatar
im gonna jump off a bridge now...
take care all...:S
Old Oct 23, 2007 | 07:50 PM
yeesh.
well i quess i should have went more into detail but i didnt so here we go : my elevation is nearly 3000ft (less air) my tune is commanding a much leaner a/f ratio then stock stage 2 (thus using less injector) and my idc is at 70-78% at wot at 7300rpm so that tells me i have a little more injector left
Old Oct 23, 2007 | 07:52 PM
an0malous's Avatar
im at 3000ft.
and 2.8 was still giving me 120%
I find it hard to believe your legitimately running that IDC.
I smell an error somewhere in the mix.
Old Oct 23, 2007 | 07:54 PM
im at 3000ft.
what is your tune and what is your a/f set at
tlax23's Avatar
^ I second anomalous.
A 78% IDC is outstanding for a 2.8 with 42lbers. No matter what the elevation.
Old Oct 23, 2007 | 07:56 PM
an0malous's Avatar
with the S2 tune it was even higher.
that was after custom tuning and leaning out to 11.5 AFR and only 7k RPM
Old Oct 23, 2007 | 08:13 PM
yeah thats really close to mine its set to be 12 afr and never goes lean or static
my mistake thats what i wanted to remember i spoke with my friend he said it was 80-90 range so i guess i dont have much injector left at all...
Last edited by hungryhip-ccp; Oct 23, 2007 at 08:13 PM. Reason: Automerged Doublepost
Old Oct 23, 2007 | 08:17 PM
thedubsack85's Avatar
yeah 100 is wide open. get 60's.. seeing near 90 isnt great but you shouldnt run into prob's.. but i dont think the 7+ rpm range is very smart. damn near over spinnin the blower.
Old Oct 24, 2007 | 11:18 AM
Area47's Avatar
Rent me! per hour
take care all...:S
race ya to the bottom.
im at 3000ft.
keep an eye on your afr after 6k. you're on borrowed time
Old Oct 24, 2007 | 12:42 PM
an0malous's Avatar
this was long ago before i bought 60s
Old Oct 24, 2007 | 12:45 PM
Area47's Avatar
Rent me! per hour
ah ha!
trickery!
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
Builttss
Oct 4, 2015 10:21 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
Builttss
Sep 22, 2015 12:42 AM
06lsj_justin
Sep 13, 2015 09:53 PM
