2.7 on CA Stage 3??
2.7 on CA Stage 3??
Stage #3 : 2.7 ZZP Interchangeable Pulley system , 1 step colder ngk IRIDIUM spark plugs , GM shortened belt , 42# Lucas Injectors , Injector Wiring Harness, Stage #3 Retune ... Est. 65 Hp over stock - 18 psi boost
The smallest pulley I've head of being used with GM stage 2 is a 2.8X.. With stage 2 and colder plugs whats the smallest pulley you can use? 2.7 is too small isn't it?
welcome to the site. what part of virgina are you from??
Last edited by ColeJJones; Apr 22, 2008 at 06:20 PM. Reason: Automerged Doublepost
A little below Lynchburg. Yeah I figured 2.7 was way too small. I'm sorta new to upgrading the SS ..Traded in my 01 GT in for it two weeks ago. 07 Victory Red, color inserts,chrome with 11k.
A 2.8 should be fine with stage 2 right? What kind of power should stage 2 + 2.8 and a CAI make? As far as aftermarket stages what would be the best one to go with and just go ahead and start with a smaller pulley and 60's ..not factong in cooling mods and what not because that would be done first if I go that route.
