2.7 on CA Stage 3??
Old Apr 22, 2008 | 06:16 PM
Perfect.disguise's Avatar
2.7 on CA Stage 3??
Stage #3 : 2.7 ZZP Interchangeable Pulley system , 1 step colder ngk IRIDIUM spark plugs , GM shortened belt , 42# Lucas Injectors , Injector Wiring Harness, Stage #3 Retune ... Est. 65 Hp over stock - 18 psi boost
The smallest pulley I've head of being used with GM stage 2 is a 2.8X.. With stage 2 and colder plugs whats the smallest pulley you can use? 2.7 is too small isn't it?
Old Apr 22, 2008 | 06:20 PM
ColeJJones's Avatar
Bannned
yes its to small. your going to push the 42s over the max. you gotta run bigger injectors. doesnt matter what your spark plugs are when your about to make your injectors go static
welcome to the site. what part of virgina are you from??
Last edited by ColeJJones; Apr 22, 2008 at 06:20 PM. Reason: Automerged Doublepost
Old Apr 22, 2008 | 06:33 PM
A little below Lynchburg. Yeah I figured 2.7 was way too small. I'm sorta new to upgrading the SS ..Traded in my 01 GT in for it two weeks ago. 07 Victory Red, color inserts,chrome with 11k.
Old Apr 22, 2008 | 06:36 PM
ColeJJones's Avatar
Bannned
nice. GTs are slow anyways
Old Apr 22, 2008 | 07:14 PM
Haha not a full bolt-on one with 4:10's compared to my cars stock state, but I will get there.
Old Apr 22, 2008 | 08:15 PM
C0baltWithM0ds's Avatar
2.7 is to small for 42's but i run it no problems car pulls pretty hard to
Old Apr 22, 2008 | 09:04 PM
A 2.8 should be fine with stage 2 right? What kind of power should stage 2 + 2.8 and a CAI make? As far as aftermarket stages what would be the best one to go with and just go ahead and start with a smaller pulley and 60's ..not factong in cooling mods and what not because that would be done first if I go that route.
Old Apr 22, 2008 | 09:44 PM
007Buff's Avatar
IMO I would piece together your own kit...get hptuners and find someone that knows what there doing when it comes to hp and have them tune you..
HEATON
Oct 16, 2015 07:21 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
