2.8 to 2.7
Old May 4, 2009 | 08:14 PM
venum_us_2002's Avatar
2.8 to 2.7
Is it really worth it, what would i gain. Mods in sig. Does it kill reliability? Is meth enough for cooling?
Old May 4, 2009 | 08:21 PM
Bika's Avatar
Fail Less.
meth should be enough for cooling, but you could benefit from a good front mount h/e.
It doesnt kill reliability in terms of your blower, but as with anything, the car is only as good as its tune.
Gains, not a hell of alot. a few whp.
Old May 4, 2009 | 09:00 PM
rico's Avatar
good thread cuz im thinking to do the same later down the road
Old May 4, 2009 | 09:06 PM
Zach06CobaltSC's Avatar
2.8 to a 2.7 isn't really going to gain much in all reality, its just going to over-spin your blower and create more heat. Hell if you want to be technical if you don't have the proper cooling mods you could be LOSING hp due to excessive heat.
Meth would be enough for cooling more then likely however a heat exchanger and or dual pass would also help of course.
I don't recommend dropping lower then a 2.8 unless you really have to for those "dyno numbers" because those smaller pulleys create A LOT of heat. Also considering you don't have an interceptor I really recommend against it. You have no way of monitoring your iat2's let alone knock.
Old May 4, 2009 | 09:22 PM
OntarioKev's Avatar
I am running a 2.7 on my setup, and I can tell you it makes a lot of heat.
I am running meth, a H/E and GM Dual pass with option B, and at the end of the strip I was seeing 152-158 F IAT2 temps, and it was probably about 65 degrees outside at the strip.
Now I am trapping pretty high in the 1/4, but it is still a lot of heat, so you need to be careful on the street, and you need some way to monitor the IAT2 and knock.
Kevin
Old May 4, 2009 | 09:39 PM
rico's Avatar
damn 152 i dont even get that after a 3rd gear pull. umm umm. i think ill stay at the 2.8. right now i have dual pass and extra h.e will be doing meth and extra tank later on
Old May 4, 2009 | 09:40 PM
rico - you would be getting that if you were at the track though. Consider when your staging your temps can be like 120+ and by the time you finish your run you can be at 150+.
My pump is on its way out also right now but I have bigger fish to fry before I fix that issue.
Old May 4, 2009 | 09:44 PM
rico's Avatar
yea true that i forgot about all that i was thinking about general 3rd gear pulls lol my bad but shoot with dual pass, meth, extra h.e and tank i should be fine
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
Builttss
Oct 4, 2015 10:21 AM
SlowSaturn
Sep 28, 2015 11:03 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
Builttss
Sep 22, 2015 12:42 AM
