2.8 and no slip
Old May 29, 2006 | 08:59 PM
silverSS's Avatar
2.8 and no slip
I installed the ZZP 2.85, and am getting NO SLIP and about 16ish lbs of boost on the stock idler and stock belt
Why is everyone installing the bigger idler pulley? How bad has it slipped for you?
IM still going to throw on the S2 belt when available
Old May 29, 2006 | 09:23 PM
2006ArrivalBlueSS's Avatar
I'm using the ZZP tensioner arm with my 3.00 with plans to put on the 2.85 after I get bigger injectors and reflash. The tensioner arm is fantastic, three adjustable settings to accomodate pulleys SMALLER than 2.50. I think you might get some slip over time as the OEM belt starts to stretch but the S2 belt is definitely the way to go!!!
Old May 29, 2006 | 10:17 PM
distillion's Avatar
thats good news
Old May 29, 2006 | 10:50 PM
*TRIX*'s Avatar
i slipped insanely sooo i bought the 3 inch idler with the 2.8 inch pulley
Old May 29, 2006 | 11:00 PM
distillion's Avatar
so me already having the stage 2 belt should be ok then??
Old May 29, 2006 | 11:03 PM
sscobalt06's Avatar
I have the 2.9, I installed it today and it doesnt seem to be slipping so far
distillion's Avatar
^^stock?
Old May 29, 2006 | 11:20 PM
Matty's Avatar
Trix, sscobalt06, which of you are running the stock belt?
I just received the GM stage 2 and also have the Intense 2.8" and am curious to see if the stock tensioner is adequate or if it is going to slip.
Old May 30, 2006 | 12:57 AM
silverSS's Avatar
If you have the S2 belt you will be set. That will take up all the slack
I have one on the way, because like said above, eventually it ***may slip, but all night its been fine, put over 70miles on it tonight
Old May 30, 2006 | 09:28 AM
Matty's Avatar
I had a feeling it would be ok. Was wondering how everyone was making out.
Thanks for the info.
Old May 30, 2006 | 10:32 AM
sscobalt06's Avatar
I have a stock belt on the intense stage 3 kit w/ the 2.9" pulley and still no sliping that I can tell.
Old May 30, 2006 | 10:36 AM
1stbluSS's Avatar
2.8 and 16 lbs of boost ? i thought that should put us around 17 ?
Old May 30, 2006 | 10:44 AM
Matty's Avatar
Awesome. Thanks.
With the stage2 belt, I shouldn't have any slipping then.
Old May 30, 2006 | 10:56 AM
BLKSS's Avatar
The stage 2 belt is one tight bugger. Took us like 20 mins just to get it over the tensioner pulley. If your not getting any squeals out of the stock belt with a 2.8 thats amazing.
Old May 30, 2006 | 04:32 PM
silverSS's Avatar
Yeah im happy, my S2 belt wont be here till mid-June, so hopefully the stock belt will hold tension.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
SlowSaturn
Sep 28, 2015 11:03 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
