2.8 vs 2.6 pulley
Old May 21, 2008 | 06:28 PM
thatotherguy's Avatar
2.8 vs 2.6 pulley
whats it the hp and tq difference between them????
Because im thinking of getting a 2.6 pulley
Old May 21, 2008 | 06:35 PM
Area47's Avatar
Rent me! per hour
im thinking you need to go into a little more detail on what you have done first
Old May 21, 2008 | 06:46 PM
Otown07's Avatar
With nothing else done, a 2.6 will make 0 hp 'cause the motor blew up.
Old May 21, 2008 | 06:48 PM
what do you mean? if your talking about injectors and other mods to support it... I already know them all.. i just want to see the tq and hp different because the last dyno i had i was running a 2.8 and 42 ibs and i made 270 whp and 260 wtq,,, numbers might be off by 1 or 2
Old May 21, 2008 | 06:51 PM
EdCobaltSS's Avatar
2.8 and only 42's and you made 270 WHP??? something doesnt sound right with that
Otown07's Avatar
270/260 on a 2.8 and 42#s sounds like your dyno was a bit off. That or you've got the mother of all freaks.
Old May 21, 2008 | 06:52 PM
XM15's Avatar
Probably a Dynojet.
SSRedSC's Avatar
You would definitely need 60s, as well as cooling mods.
pimpnwink's Avatar
QFT!
Old May 21, 2008 | 06:53 PM
SSRedSC's Avatar
Also depends on who does your tuning and how its set up.
Old May 21, 2008 | 06:59 PM
InfinityzeN's Avatar
Or if your using unsmoothed results instead of SAE modified results. Hell, I'd be at high 260s whp and high 240s ft/lbs torque if I used raw results instead of SAE. And that's with a 2.9".
Old May 21, 2008 | 07:05 PM
NamedGobalt's Avatar
for a 2.6 i've been told you should look into meth kits.. at the very least h/e and dual pass. i'm going with a 2.6/ 60's and i know i plan on getting the meth kit. I'm aiming for 290ish to the wheels.. but I think that is dreaming.. I'll prolly get more like 270 or 280 on a dynodynamics dyno.
Old May 22, 2008 | 10:54 AM
Area47's Avatar
Rent me! per hour
ah ha!
no.
Old May 22, 2008 | 10:58 AM
invisible's Avatar
You will make more on a 2.8 and 60's than with a 2.6. A 2.6 will cause so much heat that you will loose power.
Old May 22, 2008 | 11:05 AM
lsjwannabe's Avatar
more like 250 if your lucky
Oct 20, 2015 09:56 PM
Builttss
Oct 4, 2015 10:21 AM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
