2.80 44lbs
Zinner
The above post speaks the truth. i have been in this debate sooo many times......
i have a stage 2 tune with a 2.79 pulley and ebay intake and dynoed 255 hp 240 trq with a 12.5 a/f
i will say that i am right along the jagged edge and wouldn't push it any more. that being said i went to the track hammered on it all day and had 0 problems.
i JUST got back from a 1500 mile trip from Michigan to Georgia and back and she ran like a dream...
too much vibration......but thats from the tranny mounts
i have dynoed at same place since stock
after stage 2 i was pig rich.
A 12 afr is pretty high for these cars, considering the stage 2 tune puts you in the high 10s, piston pertection, just because you afrs are that still doesnt mean your idc is max, and on stage 2 injectors, and stage 2 tune on a 2.79 i really wouldnt call that safe.
http://www.stealth316.com/2-calc-idc.htm
2.8 and 42 or 44 # injectors will be fine. I have been running that setup for over a year.
I have read of 1 setup running 42# melting down and about 20 setups running 60# melting down. Don't go lower than 2.8, also try to get a header back system, that will lower your overall manifold air pressure 1-3 PSI and also get your injectors flowing a bit more as well.
I easily hit low 12's AFR with 42# and a 2.8 pulley.
Not only have I not blown up, but I have no knock retard or signs of knock on the spark plugs, that I check every 1k miles. I guess it's a matter of personal choice. I don't see the reason to got lower than 12 AFR. The only reason I know of is to prevent detonation/spark knock and if thats not apparent then why go lower.
I also had a secondary knock sensor device installed into my car during tuning that was more sensitive than the STOCK PCM (still used the stock sensor) and I never saw an issue with knock. The thing would read knock if you hit a large bump.
