2.80 Pulley Question
Old Jul 24, 2007 | 11:53 AM
williamhvx1's Avatar
Hello Everybody!
I Got A 2.80 Pulley And 44lbs Injectors To Install (alredy Did Sparks Plugs) So Here My Question Can A Chevy Dealer Install Those And Do The The Stage1 Reflash ? It Run Ok? I Got A Dealer It Will Install Stage 2 For $300 But The Dont KNOW Yet Is A Aftermarke Parts
Old Jul 24, 2007 | 11:58 AM
Area47's Avatar
Rent me! per hour
gm won't put on the 2.8
well they might, but the car also might get flagged.
that is bad.
44's?
Old Jul 24, 2007 | 12:00 PM
that is bad.
44's?
I AM SORRY WHAT U MEAN WITH FLAGGED AND YES 44 LBS I BOUGHT IN COBALTPERFORMANCEPART THEY ARE A DIRECT FIT ALSO ....
Old Jul 24, 2007 | 12:05 PM
Area47's Avatar
Rent me! per hour
holy caps batman!
flagged, as in warranty.
stock stage 2 is 42.5 lb/hr injectors. so the flash will be for 42.5's not 44's.
Old Jul 24, 2007 | 12:11 PM
holy caps batman!
WELL WARRANTY DONT GET VOID UNTIL THE CAR PRESENT A PROBLEM CAUSE FROM A MOD THAT U DID A CAR! THANK YOU I KNOW ABOUTH THE REFLASH NOW!!
Old Jul 24, 2007 | 12:33 PM
braineater's Avatar
2.8 is borderline to small for that size injectors. lots of people do it but i didnt want to risk it myself.
Old Jul 24, 2007 | 12:39 PM
Area47's Avatar
Rent me! per hour
depends on what supporting mods you do.
you "can" get away with a 2.8 on 42's if you know what you're doing. of course, one has to know what to do to get away with it, and safely at that.
Old Jul 24, 2007 | 01:29 PM
SO I 44 LBS INJ ARE ACTUALLY BETTER WITH 2.80?? ANYWAY THE GUYS FROM INTENSE RACING DID A 2.80 WITH THE 42 LBS LUCAS LOOK IN 3800PRO.C.......
Old Jul 24, 2007 | 01:39 PM
rnjmur's Avatar
The GM stage flash is not going to work correctly with 44 lb injectors. You will need to have the car tuned by a shop or someone with HPtuners. You might be able to get away with a 2.8 with 44 lb injectors but it might be borderline. I would also get some cooling mods as well if you actually want it to be "safe". If you have the install done by GM it is a good possibility that they will note it in your car and next time you go in for warranty work they will give you trouble even if it is unrelated.
Old Jul 24, 2007 | 01:42 PM
finnally something clear!!!!!!!!!! thanks...
Old Jul 24, 2007 | 02:46 PM
chevysalesman614's Avatar
i havent heard of anyone using 44lb/hr injectors in their cobalt before.. u might want to re-check that..
Old Jul 24, 2007 | 02:51 PM
Area47's Avatar
Rent me! per hour
cobaltperformanceparts.com
they are on there.
Old Jul 24, 2007 | 03:00 PM
spaz's Avatar
I would think they would work ok with the 2.8. I know a couple guys up here running 2.8 pulleys on gm stage II injectors and tune without a problem. You can't get a stage reflash at any dealership without the auth code that comes with the kits.So I think your only option is someone with hp tuners.
Old Jul 24, 2007 | 03:05 PM
well i hear all the dealer use a tek2 program from gm..
Old Jul 24, 2007 | 04:01 PM
SCcobaltSS's Avatar
I would get a Custom Tune when you do your install. I had the GM Stage 2 tune with my 2.8" for a day and my car hated me. It was pulling timing and bogging a lot. I would not recommend that tune with the 44#'ers and the 2.8" pulley.
Old Jul 26, 2007 | 03:49 PM
well yes is a 42lb injectors cpp say is 44 but that not right you look in pte website (manufacture) is listed as 42 lbs. so i can do a stage1 reflash and 2.80 pulley and belt! stage one is 42 lbs anyway.....
Old Jul 26, 2007 | 03:52 PM
yeah, if you had the stage 1 reflash, it would work.. but i think you might have a hard time getting them to install and aftermarket setup.. personally, i do not think they would do it..
Old Jul 26, 2007 | 03:55 PM
nope they say is kool but i know they will flaged my car.... but who buy a tunner car and dont mod? who bought a camaro and dint change anythig on it ?toll them that and they underthang
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
