2.85 installed!!
Old Sep 14, 2007 | 11:27 PM
SSbolt's Avatar
2.85 installed!!
well all i can say is anyone who has stage 2 and really wanna up the performance get nates 2.85 inch pulley. itts awesome
Old Sep 14, 2007 | 11:42 PM
RBC's Avatar
RBC
already done it! The stage 2 lasted 3 days before I put it on.
Old Sep 14, 2007 | 11:43 PM
SSbolt's Avatar
ya its awesome
Old Sep 15, 2007 | 07:12 AM
anthonyS88's Avatar
how much boost is your gauge showing now? i got a 2.9 but maybe i can upgrade to a 2.85 w/e i feel like driving faster
Old Sep 15, 2007 | 10:11 AM
joey26lil's Avatar
do u need a tune if u get the 2.85??
Old Sep 15, 2007 | 11:23 AM
xravenwingsx's Avatar
^^ that was my question as well...I can't afford HPT, and nobody in Utah has it. I'm thinking of going with 2.9", but was wondering if I could even go to 2.85" without any tuning/belt/tensioner/injector problems
Old Sep 15, 2007 | 11:29 AM
ecotecon18s's Avatar
i switched to the 2.85 and the damn tensioner went out on mine and ate up my stage 2 belt...but i got it replaced under warranty (got the hook up at the dealer) and now its all good. 2.85-2.8 is the smallest you can go without upgraded injectors, not sure about tensioners, but the 2.8 is pushing the limits of the injectors.
But the pull on full boost WOT is awesome, and it makes the blower scream a little more...
silentd's Avatar
you can go without atune and injectors but it isnt as reliable. i have hpt and im only stage 2. when running the tests your injector duty is around 110-120 percent duty. at your peak rpms (6500-7000).
so technically u can run it but i definetly recommend a tune and 60lb injectors for reliability
Old Sep 15, 2007 | 11:35 AM
cool, question answered. I need reliability, so 2.9 it is
Old Sep 15, 2007 | 11:47 AM
BLKblurr06's Avatar
a 2.85 pulley on stage 2 is just ok, I wouldnt say its even close to "awesome"
Old Sep 15, 2007 | 11:56 AM
silentd's Avatar
a 2.9 is runnable, its just realiability. if you have supporting mods then youll definetly be better off cooling ftw
Old Sep 16, 2007 | 04:18 PM
RBC's Avatar
RBC
I herd some people are running 100+ IDC on the stock stage 2 pulley and even on a all stock car. I think it all depends on your elevation. The higher elevation the smaller pulley you can go with to a certain extent. Even at a high elevation a 2.8 and maybe a tune would be the smallest I would go with on a 2.8. The are just my thoughts don't take them for fact. If you plan on messing around with GET SOME MONITORING so you are not flying blind and can make some what of real judgment. Just because your car feels good and is running good doesn't mean it really is.
Old Sep 16, 2007 | 08:13 PM
Onyxd04Redline's Avatar
You really want to blow up your car don't you
Old Sep 16, 2007 | 09:50 PM
SSbolt's Avatar
what are u talking about. OOO YA now i remember. ya im definatly trying to blow it up. and i plan on doing it with just a 2.85. ya man
Old Sep 16, 2007 | 09:53 PM
lnf08ecotec's Avatar
Agreed, had to take my 2.85" off bc the eaton couldn't take the heat, and started knocking.....but it does make a difference compared to the 3.066" that comes with a stage 2....
Old Sep 17, 2007 | 12:44 AM
42lb injectors + 2.85" pulley = BOOM
Do a search
Old Sep 17, 2007 | 12:47 AM
lsjwannabe's Avatar
this is just like the 2.5" + 60's = boom right... i don't believe half the **** i hear on here
Old Sep 17, 2007 | 12:52 AM
greekss's Avatar
Hey quick noob question. I have the stg 2 setup, so are smaller pulleys plug and play or do i need a pulley puller to yank them off still? If so i guess the sc needs to come off the block b/c there is no other way to get the puller in right?
Old Sep 17, 2007 | 12:53 AM
lsjwannabe's Avatar
you need a pulley puller and it is easier with the s/c off to change a pulley
Old Sep 17, 2007 | 12:55 AM
greekss's Avatar
thanks - - appreciate the input...
Old Sep 17, 2007 | 12:56 AM
lsjwannabe's Avatar
no problem
Old Sep 17, 2007 | 01:03 AM
RBC's Avatar
RBC
You DO NOT need a puller puller if you have a stage 2 kit to remove the pulley! Just the tool that came with the kit. Use that tool, loose the bolts take a 15 mm wrench on the tensioner and the pulley will pop wright off.
Old Sep 17, 2007 | 01:04 AM
lsjwannabe's Avatar
i thought he was talking about a stock car my bad its a little late
silverSS's Avatar
had this setup for over a year.
A/F dips around 10.6 @ 7k
IDC in the low 90's @ 7k
and my IAT's are relatively close to stock.
I cant complain
Old Sep 17, 2007 | 07:14 AM
lsjwannabe's Avatar
you might wanna lean out up top your idc's will be lower and you are laving some power to be had
