2.9" Gm pulley swap
Old Aug 4, 2011 | 12:32 PM
N1ckateen's Avatar
2.9" Gm pulley swap
I just ordered a 2.9" pulley from zzp to swap with the gm stage 2 pulley and was curious as to what i need to take the pulley off the hub so i can change the pulley to the 2.9. I'm not sure where the gm bolts bit is, i'm sure if i looked hard enough i could find it, but can i use anything else to take the bolts out? what tq. specs are there on the bolts or can i just snug them good with a 1/2 inch ratchet and do i need locktite? thanks!
Old Aug 4, 2011 | 12:48 PM
N1ckateen's Avatar
bump sorry i know it's a noob question and i could search it, but i'm looking for some specific answers to the questions.
Old Aug 4, 2011 | 12:50 PM
Staged07SS's Avatar
Administrator
Administrator
You need the tool for the GMS2 bolts.
The torque specs are 16 ft/lbs for the bolts.
Old Aug 4, 2011 | 01:02 PM
N1ckateen's Avatar
ok. i'll search around and see if i can find that bit. i searched and saw u said to leave the belt on losen then take the belt off swap pulleys put screws back in hand tighten then put belt back on and finish tightening i would presume?
Old Aug 4, 2011 | 01:17 PM
hawlyns711's Avatar
I tightened mine before I put the belt back on. and aren't the GM bits just an inverted torx (E)? or something different?
sprinj76's Avatar
MT2 Stage Kit Pulley Tool MT2 - Crate Engine Depot
Old Aug 4, 2011 | 01:21 PM
N1ckateen's Avatar
one side of each star tip has a straight edge the other side of the star tip has kind of a curved edge.
i'm hopin to find mine so i can avoid spending $25 on a small little bit thats lost in my closet somewhere lol.
Old Aug 4, 2011 | 01:24 PM
Staged07SS's Avatar
Administrator
Administrator
That's correct.
Old Aug 4, 2011 | 01:36 PM
hawlyns711's Avatar
you could scratch your hub if you tighten the pulley onto the hub while there is tension on the belt..
no?
not to mention that these star bits could be tricky if you even begin to strip one of the bolt heads. and the only reason you could strip one of the bolt heads is to have too much tension pressing the pulley against the hub with the belt on.
I dunno why you would place belt, and then tighten the pulley. that's beyond me and quite honestly sounds like an overall terrible idea.
Old Aug 4, 2011 | 02:06 PM
Staged07SS's Avatar
Administrator
Administrator
no?
You are reading it all wrong.
Step 1: loosen pulley bolts.
Step 2: remove belt
Step 3: remove bolts & pulley
Step 4: place new pulley on hub and hand tighten bolts (hand tighten means tighten so they are nice and snug)
Step 5: place belt on new pulley
Step 6: torque bolts to spec
I have done more pulley swaps than I can count....
The way I listed it is the way GM recommends doing it as well.
Old Aug 4, 2011 | 02:16 PM
hawlyns711's Avatar
ok, that sounds about right. guess I misinterpreted the part about hand tightening them. cheers!
Old Aug 4, 2011 | 02:18 PM
Staged07SS's Avatar
Administrator
Administrator
No prob man.
It happens. It's tough to interpret what people are getting at over the internet sometimes.
Old Aug 4, 2011 | 02:20 PM
ebristol's Avatar
Bigger injectors would be a good idea.
Old Aug 4, 2011 | 03:30 PM
Staged07SS's Avatar
Administrator
Administrator
Live on the edge man
Old Aug 4, 2011 | 03:38 PM
ebristol's Avatar
Burn! lol
You got me.
I will not live on the edge with 130% IDC...
Old Aug 4, 2011 | 04:58 PM
Boosted05's Avatar
Aren't the hubs diff from GM to zzp as well, unless I missed hoim saying he got the hub as well.
Old Aug 4, 2011 | 05:40 PM
N1ckateen's Avatar
yea zzp sells 3 pulleys that will fit the gm hub. i'm getting custom tuned at our meet next saturday. gonna put the pulley on at the meet and datalog. if all is well i'll stick with the 42's. if i have to i'll bump up to 60s. i hate how 60s idle so i'm gonna go with 42s unless i absolutely have to go to 60s. Yes i know it is risky, but it can be done.
But the problem will be addressed if it occurs.
Old Aug 4, 2011 | 05:53 PM
Staged07SS's Avatar
Administrator
Administrator
Burn! lol
You got me.
all in fun man!
Old Aug 4, 2011 | 07:03 PM
SneakyMilo's Avatar
Properly setup 60's will idle just fine. There is no reason to risk running injectors without a reasonable factor of safety.
Old Aug 4, 2011 | 07:04 PM
Boosted05's Avatar
60's idle fine for me, it's all in the tune IMO
Old Aug 4, 2011 | 11:58 PM
N1ckateen's Avatar
i'll probably be swapping my friend cause he's putting 80s on and getting an e tune the same day i'm getting the tune and i put his header on so he would sell me the 60s for 30 bucks plus the labor of putting the header on.
Old Aug 5, 2011 | 11:47 AM
ebristol's Avatar
60s are must on a 2.9" so you are making a good choice. I did some test this spring and found out some pretty interesting things about the stock and GMS2 setup.
Stock Injectors Stock Pulley Stock Tune and all the bolt-ons - Saturn ION RedLine Forums
Its a pretty good read when you get some time.
Old Aug 5, 2011 | 11:48 AM
ebristol's Avatar
FYI. 60s can handle a 2.9" on E85.
Old Aug 5, 2011 | 11:59 AM
Staged07SS's Avatar
Administrator
Administrator
fyi. 60s can handle a 2.9" on e85.
e85
Old Aug 5, 2011 | 12:04 PM
ebristol's Avatar
Yup.
95% IDC at 7k with an 11.8 AFR.
Most people would probably feel a little more comfortable with some bigger injectors but it is good to know that the 60s are not being maxed out.
