2.9" pulley
Old Apr 19, 2007 | 12:51 AM
L.P.'s Avatar
2.9" pulley
Can a 2.9" pulley be used with the Stage 2 injectors and tune safetly?
Old Apr 19, 2007 | 12:52 AM
OniMirage's Avatar
yes it can
Old Apr 19, 2007 | 01:01 AM
L.P.'s Avatar
Would I feel much of a difference?
And what if I decided to get a downpipe and header as well? I am just afriad that the GM stage 2 tune will not be supportive enough.
Old Apr 19, 2007 | 01:04 AM
OniMirage's Avatar
the difference would be in torque not much in hp so your low and mid range would pick up a good amount of power ... and the header and dp and you should gain a good amount of hp. ct has the same setup and is putting something around 240-260 tq/hp
Old Apr 19, 2007 | 01:05 AM
c0ld29's Avatar
I'm not sure but I do know you will THINK you feel a difference at least, lol
Old Apr 19, 2007 | 01:08 AM
L.P.'s Avatar
Okay, well I am thinking very seriously about doing this. I have stage 2 right now, and well I want more haha. I would get an HP tune, but nobody is remotely close to help me out with this so that is the reason I was wondering if the GM stage 2 tune would support it. Does anybody have a clue as to if this would run lean?
Old Apr 19, 2007 | 01:11 AM
c0ld29's Avatar
according to cobalt addiction the 2.8 is actually the best for the gm stage 2 tune
sorry 2.79
" The top of the groove has a diameter of 2.79” . These have been proven to run great on the GM stage 2 reflash as it is very rich fuel wise to start with and this will bring you right into the correct AFR"
Old Apr 19, 2007 | 01:13 AM
L.P.'s Avatar
There is no way I'd go down to a 2.79 with stage 2 tune, heck I"m worried about going to the 2.9. Reason I was asking if the tune was rich.
Old Apr 19, 2007 | 01:17 AM
c0ld29's Avatar
yeah the stage 2 tune is so rich that a 2.9 is definately safe
Old Apr 19, 2007 | 01:21 AM
OniMirage's Avatar
sorry 2.79
that is wrong unfortunately
L.P.'s Avatar
Can the stock tensioner and GM stage 2 belt be used?
Old Apr 19, 2007 | 01:22 AM
c0ld29's Avatar
well like I said, thats CA not me lol
Old Apr 19, 2007 | 02:20 AM
OniMirage's Avatar
the stage 2 belt is super tight as is and people were using that stock setup with even 2.8" pulleys back before it was discovered a 2.8 was bad so yeah you can use it
Old Apr 19, 2007 | 03:01 AM
syP's Avatar
syP
I just ordered a true 2.90" pulley,
cant wait to see how that feels compared to the 3.06" which is on the stage 2.
dont see how you cannot gain HP from a pulley.... since it is making the blower spin faster..... but nonetheless i cannot wait to get it on.
IIRC the boost should be around 17?
Old Apr 19, 2007 | 11:31 AM
OniMirage's Avatar
you do gain hp just not much at all. boost depends on a lot of other factors but if all you had was a stage 2 and 2.9" it should be right about 17.
Old Apr 19, 2007 | 12:11 PM
brk_05's Avatar
I have had the stage 1 with 2.9" pulley for about 3 weeks now. Love it. And yes, its about 17 PSI.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
