2.9" Pulley
Old Feb 5, 2008 | 12:40 AM
effex80's Avatar
2.9" Pulley
Few things.
First, the 2.9" pulley is also called the "stage 3 pulley"? and where is the best place to get one?
Secondly, I am ordering my stage 2 soon from CED. If i get the 2.9 pulley can i use the stge 2 belt and hub?
Third, If i just swapped the 2.9 for the stge 2 one in the box before its installed, do you think they would notice? and still warranty it if something blows up? I doubt they will measure the pulleys?
Lastly. is it safe to run a 2.9 on stock internals and cooling devices? Just intake exhaust and stge 2.
Thanks guys!
Jack
Old Feb 5, 2008 | 12:51 AM
an0malous's Avatar
the official GM stage 3 pully is 2.99
yes you can use a 2.9 pully with the S2 belt
they probably wouldnt notice....but it only takes 2 minutes to swap a pully anyway.
Yes its fine to run the 2.9
Old Feb 5, 2008 | 12:52 AM
KillerBee's Avatar
^^^^he is exactly right also look up smooth flow pullesy on here nate sell the 2.9 and its light weight for like 50 bucks
Old Feb 5, 2008 | 12:56 AM
Kaisoboy's Avatar
1. Nate...he is now a supporting vendor. many of us have purchased pulleys from Nate. Great work and craftsmanship.
http://www.smoothflowpulleys.com/
2. yes you will be fine with the stage 2 belt.
3. I would install the pulley after the dealer installs stage 2. Make sure the dealer does not put lock tight on the hub bolts and make sure to get the bolt tool back from them. Alot of people forget to get it back so they can remove the bolts to swap to a new pulley.
4. yes it is safe. the stage 2 tune runs rich so the 2.9 pulley will lean it out a bit.
Read the posts. I put a link to his web site in my reply.
Old Feb 5, 2008 | 12:58 AM
effex80's Avatar
when you say 2.9 you mean the stge 3/ 2.99" right?
Cause TTR sells the stage 3 pulley and I think its what people refer to as the 2.9"
Old Feb 5, 2008 | 12:59 AM
KillerBee's Avatar
no the stage 3 pully is 2.99 almost 3" nates pully is 2.90 pully
Old Feb 5, 2008 | 01:03 AM
effex80's Avatar
Sweet! I see anomalous has a how to vid on a pulley swap.. But is it really that easy?
Old Feb 5, 2008 | 01:04 AM
KillerBee's Avatar
where can i find this nate guy
Right here email him he excepts pay pal i received a pully from him he is a great guy/vendor
Old Feb 5, 2008 | 01:06 AM
Kaisoboy's Avatar
Obviously this guy does not read everyones posts. If he had just read mine I posted the link 5 posts ago. So why do we bother.
an0malous's Avatar
all the companies have their own little stage kits
stage 3 could be very misconstrued.
so generally when you say stage 1 2 or 3, people will assume you mean the GM kits.
Stage 1 uses the stock pully
Stage 2 uses 3.07"
stage 3 uses 2.99"
and when i say 2.9, i mean 2.90" yes.
if i mean 2.99, ill say 2.99
Old Feb 5, 2008 | 01:08 AM
EceSSiveMod's Avatar
2.85 ok on stage 2?
KillerBee's Avatar
Originally Posted by EceSSiveMod
2.85 ok on stage 2?
you should get a tune with the 2.85
Old Feb 5, 2008 | 01:09 AM
Kaisoboy's Avatar
2.85 ok on stage 2?
yep..but some may say no. It has to do with IDC. I am at 3500 ft SL and my IDC are at 90 % WOT. I agree and recommend a tune.
Old Feb 5, 2008 | 01:11 AM
what would the tune be needed for
Old Feb 5, 2008 | 01:12 AM
KillerBee's Avatar
becuase your IDC is gunna be to high probably so with a tune it can keep your car from leaning out
Old Feb 5, 2008 | 01:14 AM
effex80's Avatar
Sorry bro I saw yours 2 sec after i posted, you guys r quick!
Thanks a ton for the info.
My purchases will be made shortly.
Old Feb 5, 2008 | 01:15 AM
im dumb none of this makes since to me haha
Kaisoboy's Avatar
You should always get a car tuned with any performance mods. now some mods don't necessarily need a tune but it is always a good idea. With a 2.85 you are forcing more air into your combustion chamber. So tuning your AFR, MAF,VE and PE tables is recommended so you don't blow the motor by leaning it out.
stage2's Avatar
so with a 2.90 how much whp would i gain over stock stage 2 pulley 3.07"?
10-12whp?
Old Feb 5, 2008 | 01:18 AM
lsjwannabe's Avatar
you have some room to work with on a stage 2 tune with a 2.85 there is power to be made, i would suggest a tune, if your worried about idc's get bigger injectors then
10-12whp?
yeah around there, depends on the tune and tuner. Some people like to push the envelope others like to play it safe.
Old Feb 5, 2008 | 01:19 AM
Kaisoboy's Avatar
Great you wont be disappointed. You may also want to get his new bolts also then you dont have to use that stupid GM tool.
Sorry did not mean to bitch. Just had a shitty day. My bad.
stage2's Avatar
Gm stage 2 tune would be ok to run 2.90...
10-12whp is a good gain for under 100$
is a 2.9 on a stage 2 pushing the envelope
Old Feb 5, 2008 | 01:20 AM
KillerBee's Avatar
10-12whp?
The weight of Nates pully is so light that it weighs about the same as an empty 12 oz can of coke
No its safe
from nate its only 55 bucks
Old Feb 5, 2008 | 01:21 AM
Kaisoboy's Avatar
I am not a big fan of the sixties. To many guys blowing piston 4. Not sure if its there tune or not. I also believe that HPtuners has a problem calculating IDC. I have discussed this with many guys and we all seem to agree. you have to remember that HPT was originally for V8's.
