2.9 Pulley INSTALLED!
yeah 2.9 with stage 2's seem to be the safest way to go. headers, exhaust and intake with this setup will really bring our cars out. thank god for nate. nate's pulleys are lighter than the stage 2 pullies right??
yeah i just didnt know if that was the stage 2 size pulley or what because it has no description of what size your buying. i just left him him a message on the instructions to seller
Yeah STFT works all of the time, the only time LTFT is changed is when STFT is taken out of range + or -. So if you reset the ECU it will be learning without other previous written info on the LTFT and ignition advance, this may take longer to actually fully learn in, but since it will be on a clean slate the ECU will not see anything as abnormal.
I know it's not going to actually help performance.
Sorry I worded some things wrong.
Couple little things that are specific to this PCM. There is no ignition learning (knock learn). There are parameters in the tune for it, but it won't use them. Also anything abnormal will be seen as a + or - 20% fuel trim in the LTFT values and will throw P0171 or P0172 respectively. Other than those tiny details you are dead on. +rep sir.
yes if you have stage 2 already you can just unbolt that pulley and replace it with a smaller one..i think 2.85 is the smallest you can go with stage 2 though. i just bought a 2.9
oh and ravewings i used to live in layton, on hill afb
Just like everyone else, the dealership kept the security tool in my Stage II kit... Don't we have some do it yourself members willing to start a tool sharing program?
coughcoughorcrateenginedepotcoughcough
The mechanic left a HUGE screwdriver in the cowl of my car, I should call him and propose a trade.
Last edited by xravenwingsx; Jul 4, 2007 at 11:51 AM. Reason: Automerged Doublepost
patooyee
Oct 1, 2015 01:07 PM
