2.9 pulley on...problems HELP
Old Oct 8, 2007 | 05:10 PM
arng22's Avatar
ok so i got my 2.9 and it squeeks like crazy
is the piece that is squeeking
do i need to get the belt tightened? it seems like it is bouncing up and down
(NOTE* i DO have the gm stage 2 belt on)
Old Oct 8, 2007 | 05:11 PM
rallyracer's Avatar
Your Pic isnt working.
But Yes I think you need to get the Stage 2 Belt ASAP, it should fix the problem.
Old Oct 8, 2007 | 05:21 PM
arng22's Avatar
wtf it never works h.o
https://www.cobaltss.net/gallery/sho...atid=favorites
that is the pic
and i already have the stage 2 belt...
Old Oct 8, 2007 | 05:22 PM
matt_SS_205's Avatar
isn't that the tensioner?
Old Oct 8, 2007 | 05:23 PM
OniMirage's Avatar
arng22's Avatar
yes, it is bouncing around squeeking...would i have to tension the belt for that to stop?
Old Oct 8, 2007 | 05:24 PM
BallsoutBalt's Avatar
Originally Posted by OniMirage
Good call man!
+1 rep.
Old Oct 8, 2007 | 05:42 PM
Ryze's Avatar
if your tensioner is bouncing around squeaking, then you probably need a new tensioner..
its a self tensioner so you would not be able to "tension" the belt any more
Old Oct 8, 2007 | 05:50 PM
3ds138's Avatar
Ur belt is probably not on right.. you could be out by a groove
Old Oct 8, 2007 | 05:51 PM
arng22's Avatar
hmm any idea how much this would cost?
Old Oct 8, 2007 | 05:53 PM
Area47's Avatar
Rent me! per hour
make sure it is on all of the pulleys correctly
Old Oct 8, 2007 | 06:07 PM
KillerBee's Avatar
You should put on the stage 2 belt with that small of a pully for one thing then second you need to make sure the belt is in all grooved specially the pully under the superchager
here is a pic
Old Oct 8, 2007 | 08:45 PM
ninja44's Avatar
Check belt alignment and if that doesn't solve it a new belt will, I'll put money on it!
Old Oct 8, 2007 | 08:50 PM
SmOKe JeNsOn's Avatar
Ballsout u take some updated pics of ur ride and i mean now!!!! lol. It looks clean as hell. that and i wanted to put some of the window visors on mine but didnt know how they would look
Old Oct 8, 2007 | 08:51 PM
mkulrey13's Avatar
...works for me
Old Oct 8, 2007 | 08:59 PM
ecotecon18s's Avatar
dude, i put my 2.85 on and mine started squealing too. I left work and got on it pretty hard and the tensioner gave out and shredded my belt... thanks god I was only a mile from the dealership...ever drive a SS/SC with the blower detached? ***** man, there are none there...
Old Oct 8, 2007 | 09:42 PM
killerbeecobalt's Avatar
another way to eliminate the belt slipping is pulley boys makes a different tensioner bracket that will take up the slack in the belt
Old Oct 8, 2007 | 09:44 PM
braddddddd991's Avatar
lawl
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
