2.9 users.. IAT2 temps when DD?
Old May 5, 2008 | 01:56 PM
Acidangel_5.0's Avatar
just as title states...
seeing what you 2.9 guys see on your IAT2 when just daily driving.. mines starting to get nervously high and i was seeing what you guys were running for cooling mods and temps after the mods.
Old May 5, 2008 | 03:48 PM
INFE's Avatar
When my car is at idle mine IAT2s are at 151 lol
Old May 5, 2008 | 03:52 PM
M-Dub's Avatar
I has a 2.80 and I see 115-120
Old May 5, 2008 | 03:53 PM
3fo893013L's Avatar
2.7 no cooling mods. 125.
Old May 5, 2008 | 03:54 PM
M-Dub's Avatar
I find that very hard to believe!
Old May 5, 2008 | 03:56 PM
BriantheLion26's Avatar
I got a 2.9. Cruising I see about 15-18 degrees over the IAT2. I just did some logs and the iat1 was around 75 and my iat2 got up to around 130 on a 3rd gear pull. I have a cobra h/e.
hm.. okay.. this is what i been hitting since the weather is getting alittle warmer..
i have actually seen it top at 171 just sitting in traffic..
Old May 5, 2008 | 03:59 PM
M-Dub's Avatar
I was seeing 11-12* differences on normal driving without getting into meth spray!
Cobra H/E with 70% water 30% coolant mix
Old May 5, 2008 | 04:00 PM
Its going to rise when you are not on the gas. You have no air moving.
Old May 5, 2008 | 06:08 PM
LopsidedJester's Avatar
171 is a little too high for iat2's for just sitting, thats almost coolant temp, i have seen 150 even around 160, but it shouldn't really get above that unless you are in an insanely hot environment and when the coolant fan kicks on it usually drops back down a little.
WOT is a whole different story, i was doing a run the other day and mine seemed to top out at 145 degrees after going into fourth gear a little. 65-70 degree weather. Cruising constant on highway i see 18-30 degree difference, small roads with lots of stops i see mainly 30-40 degree difference. I have a small leak in my system so its not running to its full potential yet.
cooling mods:
2.9" pulley
dual pass
option B
front mount h/e
jabsco pump
Old May 5, 2008 | 08:39 PM
3fo893013L's Avatar
I can post pictures if you like I get up to 140 at WOT for a long period of time when I keep doing hard runs but 125 all the time.
Sean Cummings
Mar 9, 2018 12:26 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
medic710
Sep 6, 2015 08:53 PM
