2 cylinder misfire lsj fix
my buddy bought a 2007 lsj for 4000 bux, had a p0300 random misfire, well cylinder 2 and 3 were misfiring, when i opened the graphs they were very similar. switched plugs and coils with 1 and 4 didn't move the misfire as expected. well anyways i did a crankshaft position varience relearn and it fixed the issue. just figure id post this up for anyone having a 2 cylinder misfire on a lsj. the mechanic from previous owner said it needs 4 ignition coils which it didn't. hope this helps some ppl
not so sure honestly. picked up 60k misfires in about 10 minutes n like i said the graphs were almost identical. i was about to do a injector balance test then found this info on identifix which most ppl dont have access to, figured id post it up for everyone
Like I said I may have a complete misunderstanding on what a crank relearn actually does. That's mainly the reason I asked the question was to see if that situation was possible.
Edit: I think I misread your statement. In the context it would appear you meant it was falsely registering misfires. I originally read it as it was registering actual misfires.
I was curious because my understanding of what a crank relearn does (could easily be wrong) is that it teaches the computer what crankshaft acceleration characteristics to expect with each cylinder fire. If the ECU reads a different acceleration result than it expects it registers a misfire. If this premise is true couldn't there be a situation where the ECU is registering a misfire when the cylinder actually is firing and a crank relearn would correct the false positive?
havent looked at it yet but my buddy said the code came back after 150 miles of driving. he went to autozone its a p0300 like before but its not blinking this time -_- when i did the relearn the misfires were entirely gone what would u guys b leaning towards here? im gonna check it out again tomorrow
well it has a longtube header n catted dp. the previous owner for whatever reason spliced into the o2 sensor n made it 2 feet long n used solid gauge wire as the extension lol i put in a new one n just moved the harness closer. l also put in the stock plugs cuz it had brk7e's or something along those lines. the o2 readings seemed to b switching faster from lean to rich from 100 to 900 mv. well the p0300 and p1133 is gone and of course it gets a p0171 but didnt set the cel. kid bought a real gem for 4000 bux.....
BlackWidowSS07
Dec 16, 2010 10:30 PM
